It is currently Mon Apr 24, 2017 7:10 am Advanced search
TIG pedal build
Re: TIG pedal build
Postby Keith_J » Tue Dec 20, 2016 9:46 pm
Looks like something I can fab..I have the wc torch mounted control, great for off bench welding. But a tad clumsly for dynamic power control..learned to use pulsed instead.
Keith_J
Re: TIG pedal build
Postby Olivero » Wed Dec 21, 2016 7:13 pm
If that's what you did with "no electronics experience" I don't even know what I would classify as........
Very nice build and the knobs look awesome, I think your idea of putting most electronics in a seperate box is a good idea as you might get tired of reaching down and adjusting but then again, maybe not. Either way, looks great.
Olivero
Re: TIG pedal build
Postby AndersK » Wed Dec 21, 2016 11:01 pm
Olivero wrote:I think your idea of putting most electronics in a seperate box is a good idea
x2
Think I will do the same, put the pot in a separate box and make it possible to use the torch switch without changing connectors.
Too often I change the max current while repositioning the pedal with my feet.
AndersK
Re: TIG pedal build
Postby Keith_J » Thu Dec 29, 2016 5:44 pm
I'm doing something similar. Have been using a Weldcraft RCCS 14 for 5 years but now need foot pedal. The dial is actually a spur gear at around 13 teeth to the inch so I used a 1/2"x 13 UNC tap to thread the inside of a plastic pipe, then cut the pipe into strips to make a rack. Simple and fast.
Same kind of pedal but a pull-pull cable system to pull the rack. No mods to the RCCS 14
Keith_J
Re: TIG pedal build
Postby JFF45 » Fri Dec 30, 2016 4:45 am
My first time replying to a thread on this forum so hope it works..
The pedal supplied with my machine had a 1k pot on the side that was supposed to limit the max amps but when I opened it to see why it didn't work I found it had no wires connected to it. It was only there for the sales brochure pic, lol.
I added and wired in a 25k linear pot to limit the range but found the knob on the pedal itself not very practical to use down there so I removed it and put it in its own box close to the machine.
John
JFF45
Re: TIG pedal build
Postby DennisCA » Sun Mar 19, 2017 1:39 pm
Olivero wrote:If that's what you did with "no electronics experience" I don't even know what I would classify as........
I recently finished that mod, I also got a new cable with 5 wires in it, so now I only got one cable running from the pedal and the controls in a plywood box on the welder. Still a bit half-assed, not quite sure where I want to place it, but I am thinking of bending a bracket so I can just hook the box over the welder and it can hang on the side.
With the new CK17 torch and it's super-flex cable, it's a whole different ball game.
DennisCA
Re: TIG pedal build
Postby WoodpeckerWelder » Sun Mar 19, 2017 5:28 pm
Definitely a great example of necessity being the mother of invention. I have found that most folks in this trade are smarter than the average bear anyway. Great job! :)
"Why is there never time to do anything right the first time but always time to do it again?"
WoodpeckerWelder
Re: TIG pedal build
Postby DennisCA » Mon Mar 20, 2017 3:37 am
Thanks, though I am not in the trade, just a hobbyist who started in 2015 with an old used stick welder.
DennisCA
Re: TIG pedal build
Postby WoodpeckerWelder » Mon Mar 20, 2017 10:51 am
DennisCA wrote:Thanks, though I am not in the trade, just a hobbyist who started in 2015 with an old used stick welder.
Hobbyist or not, it takes a bit of knowledge about a lot of things (metallurgy, thermal dynamics, electricity in general) to be a fairly competent welder. You may have picked it up as a hobby, but I bet you learned a few things about those subjects along the way. :)
WoodpeckerWelder
Previous
Return to Welding Forum General Shop Talk
