Thanks for all the reply's,
I will probably buy one of those HF notchers, I believe they can be run off a regular electric drill or a drill press which is a plus point for me, I can definetley see that coming in handy, a lot.
Unfortunately, they want this thing done in the next 2 days so I have a guy out on site doing the cutting, notching and fitup during the day and I come out at night to do the welding and make sure its all correct, which is fine with me and we will probably make the deadline but I spent 2 hours welding up holes, inserting spacers to fill gaps and welding them in.
I Also used the MIG to fill holes as it can run weak enough for me to stack the welds, takes a couple of minutes of non-stop welding to fill the hole but it gets there and I then have a backing of sorts then I stick weld over it.
Just a lot of time to fill holes, proper fit-up would make a world of difference here. But I can say now that I have no doubt in my mind that this thing is really, really strong. Its a seriously supportive design, way overkill for tires in my opinion but they want the existing one duplicated so here we are.... Building structural bridge supports for tires
You can run them with whatever drill you have, even battery powered.
Jeff, what Noddy said.
The smaller hole saws aren't that expensive compared to a rotabroach. The Bacho (Snap-On) hold up quite well even in SS if handled with care.
Thanks Anders..Eastwood has a nice notcher I might have to get but I don't want to buy their saws, I would rather get Morse or Blu-mol..it hurts to wreck a good tool but I know notchers are hard on bits.
Well, here are some pictures of my project all done and painted.
Took longer than I expected but it turned out pretty good.
- IMG_1861.jpg (36.51 KiB) Viewed 827 times
- IMG_1850.jpg (53.98 KiB) Viewed 827 times
- IMG_1858.jpg (66.86 KiB) Viewed 827 times
- IMG_1864.jpg (49 KiB) Viewed 827 times
I do it a little differently on something like that. Get your angles and cut the pipe as if it were swauare tube, Then go to Lowbuck tools and buy the notcher with the appropriate kit for the tube you'll use.I can bang that rack together in short order with that and some .035 wire in the mig.
The only way I ever break out the Pro-tools hole saw type kit is fancy stainless or copper for a jewelry fit. Everything else goes to this
https://www.youtube.com/watch?v=7gNov_ue4N4
youtube of guy doing copes with basic tools.https:
//www.youtube.com/watch?v=mHBanmfn_CA&t=40s
