It is currently Sat Jan 20, 2018 4:45 pm Advanced search
Airco DIP PAK 225
Airco DIP PAK 225
Postby 71dumper » Fri Jan 27, 2017 10:19 am
Does anyone know the workings of a Airco DIP PAK 225? I picked up one recently and have a question about it's abilities. It has a migget spool gun for aluminum and a standard mig gun hooked up through a euro connector. Unit works for both of these although the mig wire feed motor does not always run. Still determining why. But my question is whether or not it can also stick weld? It has a looped positive feed on the front that appears once you disconnect, you just connect your stick cable assembly. But when I do so, nothing. No burn, not even a spark etc. Does not appear to have any switches external to make this work. Any ideas?? Thanks
71dumper
Re: Airco DIP PAK 225
Postby Poland308 » Fri Jan 27, 2017 6:16 pm
Not sure but the welding current may be controlled by a contactor that's only pulled in when you pull the trigger. Some welders have a switch to hold the contactor in if your not in mig mode.
Postby 71dumper » Thu Feb 02, 2017 9:56 am
I didn't realize how "rare" this welder must be. Info is virtually impossible to find online.
71dumper
Postby old dirt rider » Tue Mar 07, 2017 9:11 am
I just bought the same welder last week and I was able to get the owners manual from esab
old dirt rider
Postby marjac79 » Mon Dec 11, 2017 4:21 pm
does anyone have a manual for the airco dippak 225? esab won't return my emails and by phone iam getting the run around.
marjac79
Postby Poland308 » Sun Dec 31, 2017 9:42 am
