more rust removal
Posted: Tue Feb 21, 2017 11:45 am
by Granddaddy
I need some advice, I am up against it.
I have a project at work that is going to be a bear if it comes to elbow grease alone, I have about 600 lineal feet of steel gutter inside of a passage way that is badly rusted and all the rust has to be removed for repair and to be refinished. I know it sounds strange being a gutter but I cant use water to flush so I cant use anything that will continue to etch either. I cant close the space down so I cant use any fuming chemicals or any method that creates air born dust. I am stumped and I hope someone here has been in a similar fix and found a way to employ some power tools or " GREEN" chemicals.
many thanks.
Re: more rust removal
Posted: Tue Feb 21, 2017 2:08 pm
by homeboy
Sounds interesting! I am wondering if somewhere in the process a Rust Converter product might feasible? I have used it occasionally on rusty areas hard to get at and clean -body seams etc. Prep is minimal. If you search it there are several formulations for different applications. Good luck.
Posted: Tue Feb 21, 2017 4:37 pm
by kiwi2wheels
homeboy wrote:Sounds interesting! I am wondering if somewhere in the process a Rust Converter product might feasible? I have used it occasionally on rusty areas hard to get at and clean -body seams etc. Prep is minimal. If you search it there are several formulations for different applications. Good luck.
http://www.por15.com/
Posted: Tue Feb 21, 2017 7:31 pm
Some paint / finishing companies have special grinders hooked to big vac systems. I've seen them grind off epoxy paint and cement in food factories in areas that couldn't be contaminated or shut down. If there set up right they won't leave or spread any dust or fumes.
Posted: Wed Feb 22, 2017 8:05 am
by Granddaddy
we suggested using a rust converter but we don't have a big enough window of time for the cure.
initially we were told we couldn't close the space down at all then it was we could shut it down for 12 hours now the lease holder is bucking that so it looks like we are back to not shutting down.
many thanks.
Posted: Wed Feb 22, 2017 8:11 am
Posted: Wed Feb 22, 2017 8:13 am
by Granddaddy
KIWI, P308.
good info, I have already bought material but will keep that link Kiwi.
I think we will give the vac idea a try P308.
thanks to all.
Posted: Wed Feb 22, 2017 8:15 am
Cool vid. Read down threw the comments and noticed it's only 600,000$.
Posted: Wed Feb 22, 2017 3:33 pm
by noddybrian
Well apart from the price I so want one - nearly everything I get to work on except boat handrails is rusty ! I wonder if they do free demos ? my truck bed could do with it - no wait - I don't think I'd have any truck bed left it's only the rust holding the filler together !
