If you saw how many clamps I have you would understand. I have a bin under my welding table full of clamps and I have been known to plasma cut the pads in half and/or weld the clamp to the work and have to cut it off or several other ways to abuse clamps. I don't believe in buying junky tools either but some Harbor Freight stuff you can get away with like their clamps. VG clamps, $20+ a pair..HF $4...I also like to make specialized clamps for certain things and I don't mind sacrificing a $4 clamp for a one-off project.Farmwelding wrote:How do you get away woth not using every clamp you have Jeff. Seems like every time I need to use vise grips I'm always asking for another one. I also will argue till the day I die that you should never buy cheap knock offs unless you hit them with a torch and cut them vise grips will lest forever and if the crack which they will, you could always weld them up and they work just as well the day they came out of the box.
I have no less than 15 different kinds. And lots more styles that I've worn out and haven't replaced till I need them next time. I buy both the name brand and the cheap stuff. I think I probably use regular c clamps of various sizes and depths more than anything else.
- Farmwelding
Fair enough Jeff, need those specialty clamps for one or two little projects. You always have a feeling in the back of your head that it isn't a good idea to weld some plate on a $20 clamp.
I have a number of vicegrips but the most used is my pair of "6ln". Had/have the same pair for 35-40 years, use 'em more than any 'plier' type I own. (ie vice grips-channel locks-pliers-etc)
-c-
-c-
- Farmwelding
Gonna pick up the one with a knife and screwdriver now. Not worth it to me. already carry the knife and a multi tool which has a screwdriver and if I wanted a multitool with a locking pliers I'd break down and buy the Leatherman crunch.cornmuse wrote:I have a number of vicegrips but the most used is my pair of "6ln". Had/have the same pair for 35-40 years, use 'em more than any 'plier' type I own. (ie vice grips-channel locks-pliers-etc)
-c-
