It is currently Thu Feb 22, 2018 3:12 am Advanced search
Mig Vs Stck for project???????
Re: Mig Vs Stck for project???????
Postby homeboy » Fri Mar 10, 2017 9:37 pm
Don't have any idea what you have for stands but if they are decent size can you just make longer extensions to slip In with a pin to keep the bottom off the floor for stability? Clamp or weld on a crossbar to height req'd to spin and clamp or weld some X bracing if the stands don't have enough stability on their own. You only need a crossbar 2ft or less because steel on steel slides real easy. Just a bad habit of mine always trying to figure how to do stuff! :?: :idea: :ugeek:
homeboy
Postby Poland308 » Fri Mar 10, 2017 11:51 pm
Not a genius. It's just that doing field work in mechanical rooms I have a 50/50 chance of supporting stuff from under or above. Sometimes a combination of the two to be safe.
Postby thatoneguy » Sat Mar 11, 2017 9:19 am
I just have some 3 ton normal height jack stands. I think I'm just gonna do the supporting from the rafters idea. Build some rigid and reusable shackles hanging from them and tada!
Everlast Power I-MIG 275P
Everlast Power TIG 250EX
Everlast Power Plasma 80S
Lincoln AC/DC Tombstone
Smith OxyAcetylene
thatoneguy
Previous
