OH NOPeteM wrote:It's not just Harbor Freight either. I get those extra bolts working on my brakes too?
When you MIG, you ought to spray your surfaces (including the table) with Anti-Spatter spray. It will prevent the spatter beads from sticking. After you're done, a cold chisel will literally knock them off with no residue or scarring.
As for your table, clean it well with Acetone or a non-chlorine Brake Cleaner and some shop towels. See if that makes a difference.
Tacking to a table top is a common practice. It keeps pieces in place far better than clamps alone, unless you have a filtering table. Mine I made from 5/8 plate, mag drilled 5/8" holes on a 3x3 tube base. Its 4'x'6 and a beast but offers great room to work. Replacing it as we speak (so to speak) with a 3/4" table because my buddy wanted to build one so I sold him mine and replacing it. I'll have less than $750 in it and 24sq/ft of work area. Only way to go!
- Chips O'Toole
The weird thing about the extra parts is that they don't fit the table.
I've wonder occasionally if some underpaid assembly line worker is having an occasional joke at our expense when we find those extra pieces.
While dropping pieces from a completely different packaging line in the box: "Hey Zhao, how long do you think the crazy American will scratch his head when he can't figure where these go?"
Joking aside, I have the little folding welding table from HF, and a few beads of aluminum TIG welding while clamped on the top of the table started peeling the coating off in flakes and sheets. I'm guessing it's a cheap attempt to yellow zinc plate it, that wasn't all that well prepped.
-Josh
Greasy fingered tinkerer.
WildWestWelder
- WildWestWelder
- Chips O'Toole
You could look at it but flip your helmet down.
