I don't "whip" 601X rod unless I have a gap larger than the rod diameter. I use a "bury-rod" technique that almost welds itself if you keep the right push and angle.Farmwelding wrote:6010 and 6011 are virtually the same rods. Slight differences in the coating but they run very similarly. You get alwxcellent penetration on both and both are used with a whip and pause so practicing is the same for both to get the feel of a rod.Beardly47 wrote:If I have to be able to weld 6010 then from what I have seen I need either a stick specific machine or I cannot afford a machine that can do 6010 and AC/DC TIG with all of the fancy settings. From my understanding 6011 is very similar to 6010 and if anything 6011 might be harder to use than 6010 correct me if I am wrong but would I not get near the benefit from practice running 6011 in place of 6010? Everlast make the 200ST that has a dedicated 6010 port and I could get the accessories to do lift start TIG although I was really interested in HF start and being able to do really thin material including aluminium.
