It is currently Wed Jun 28, 2017 9:55 pm Advanced search
Preventing Distortion on Flat Plate
Postby cjarnutowski » Wed Apr 19, 2017 11:58 am
Hi guys, thanks for having me.
I tried to search for this but its pretty difficult to form a query for this specific question.
I am welding a 3"x.25" round tube to a 24"x24"x.25" plate, dead center. The material is steel and the process is TIG. I was hoping to hear some of your tricks for preventing the plate from "cupping" up toward the post on the side of the weld.
Any wisdom is appreciated,
Thanks,
Chris
cjarnutowski
Re: Preventing Distortion on Flat Plate
Postby exnailpounder » Thu Apr 20, 2017 6:17 am
Welcome to the forum! Plate is the worst offender for distortion. I have had some success with tacking a couple pieces of angle on the non-weld side, clamping the piece down, doing the weld and then breaking the tacks and grinding them off. This isn't always possible but it helps.
Postby Farmwelding » Thu Apr 20, 2017 6:21 am
Depending on the use of the part, you could take another thick plate and tack it to the base plate on this. If you need an example, Jody has a video about mig welding aluminum that demonstrates this with aluminum plate
Postby motox » Thu Apr 20, 2017 6:24 am
presetting can help as well. you will have to try a couple of pieces
to see how much set to put into the flat piece to end up with a near
flat finished surface.
motox
Postby Mike » Thu Apr 20, 2017 6:51 am
Chris, welcome to the forum.
M J Mauer Andover, Ohio
Linoln A/C 225
Everlast PA 200
Mike
Postby Poland308 » Thu Apr 20, 2017 7:29 am
Leave a gap between the plate and the tube when you tack them togeather. Gives a little relief from shrinkage as you weld it.
Postby AKmud » Thu Apr 20, 2017 10:53 am
Clamp the plate solidly to a table or a strongback of some sort if you can, and don't un-clamp it until it has cooled completely.
AKmud
Postby Arclight Ironworks » Thu Apr 20, 2017 10:55 am
cjarnutowski wrote:....I am welding a 3"x.25" round tube to a 24"x24"x.25" plate, dead center. The material is steel and the process is TIG. I was hoping to hear some of your tricks for preventing the plate from "cupping" up toward the post on the side of the weld...
What can you tell use about the intended use of this welded item? Static, dynamic, cyclical loading? Access to oxy-propane or oxy-acet torch?
Option #1. Micro tack the 1/4in round tube to the surface of the 1/4in assembly plate. 4ea 1/2" long tacks at cardinal positions on the clock. Cut 2ea 3/32" TIG filler wires into 24" lengths. Set aside. If available, sever another section of 2ft x 2ft x 1/4in steel plate as fixturing for your 1/4in assembly plate.
Stack up, from bottom to top. 1/4in fixture plate + 3/32" TIG filler at third-points on the surface of the 1/4in fixture plate + 1/4in assembly plate. Clamp the fixture plate to the assembly plate, bi-diretionally. This sandwiched arrangement "preloads" the system and introduces a micro-camber. Note, a fixturing plate is not req'd and you can easily camber the assembly plate directly to your welding table.
Weld the unit in quarters (e.g. 12 to 3 o'clock, then 6 to 9, then 6 to 3, and finally 12 to 9). Allow unit to cool, completely. Unclamp the assembly plate from the fixturing plate (or weld table). Inspect and FlameStraightening, as required, via oxygen-pro/acet torch by applying heat to the BOTTOM of the 1/4in plate.
Option #2. Disregard the 1/4in fixture plate approach. PreHeat the tube and entire assembly plate to 150F. Tack, followed by weldout a la the above technique. Allow the unit to cool. Inspect and FlameStraighten.
Unsure if you are experienced with oxy-fuel and FlameStraightening. We could walk you through the baseline technique if you have access to the equipment.
Understand that you cannot PREVENT heat from doing it's thing. Ever. Even placing a Battleship or M1 Abrams Tanks on the system as fixturing will not prevent warping. Minimize, yes. Eliminate, no. Atoms within the Elements are of star dust. Strong and Agile like the HoneyBadger.
Approach heat as a "tool". Apply to your advantage to affect the geometry during weldout and minimize distortion. In this situation, TIME between welds and attack approach are your allies.
Purpose, then passion; practitionership and practicality. Patience. Obsession and hard work. That's the discipline.
Arclight Ironworks
Postby WildWestWelder » Thu Apr 20, 2017 11:13 am
The first question I have is how much cupping are you willing to put up with. Second, what material is the 1/4" plate? Is it cold finished? If it is then good luck, never had any luck with that. If it is hot rolled (A36) you shouldn't experience very much cupping unless you need it absolute flat.
WildWestWelder
Postby PeteM » Thu Apr 20, 2017 11:26 am
I'd place the plate on the table, the frame on the plate, and clamp them together. Then place/clamp some aluminum angles inside the frame on the plate to sink the heat. Let the square tube take most of the heat.
Anything beyond that begs the question "How important is it?"
PeteM
Next
