What about making workshop using steel buildings?
Posted: Thu Sep 28, 2017 8:05 am
by tracybaker
Hey all
From my childhood, I love welding and always dreamt to be a welder. I use to do small types of welding in my teen years and am planning to enter into the professional scenario. I want to start a small workshop attached to my home. For the time being, I want to start it as a small venture. I will have some welders working in my welding workshop.
Now, the issue is related to the building of the workshop. I will not have much balance after buying the welding tools and setting up initial facilities. I don't want to build the workshop in a grand way. And am thinking of cost-effective plans.
Last day, I came across steel buildings. I don't know whether it is of low cost. What about using steel for building my workshop? Is it a convenient solution?
I stay in Toronto. Many companies in Ontario provide steel buildings which are premanufactured. Is it a brilliant plan? Does anyone have their workshops built with steel? I want to know the pros and cons and if they are affordable. Expecting your responses.
Thank you.
Re: What about making workshop using steel buildings?
Posted: Fri Sep 29, 2017 4:23 pm
by ldbtx
As far as I'm concerned, steel is the perfect material for a welding shop. Sturdy, fireproof, and easy to modify as far as partitions and such. It's what I plan to use when I build my "retirement" shop.
Posted: Sat Oct 28, 2017 10:41 pm
by Jw3
Idb where in north central Tx are you? I'm in Corsicana.
