It is currently Sun Oct 22, 2017 2:17 am Advanced search
Cutting torch pressure settings Static or residual
Postby Homemade » Tue Oct 03, 2017 9:17 am
When properly setting up a cutting torch, I’ve always just eye balled the pressure settings and adjusted the valves on the torch until I got a neutral flame. Now I’m realizing that each torch tip has specific pressures and thicknesses it’s designed for.
When setting the pressure, is it supposed to be set with the torch off or flowing gas?
Homemade
Re: Cutting torch pressure settings Static or residual
Postby Artie F. Emm » Tue Oct 03, 2017 10:31 am
Dial in settings with valves closed. In case it's helpful, Jody has a cutting torch video here-
http://welding-tv.com/2011/09/26/cutting-torch-tips/
Sent you a PM about your SMAW questions from another thread. Sounds like you've got some projects going!
Dave
aka "RTFM"
Artie F. Emm
Postby LtBadd » Tue Oct 03, 2017 6:50 pm
You can find pressure settings HERE (opens a PDF) in Victors (ESAB) welding and cutting guide
Insert witty, sarcastic, or philosophical remark here.
LtBadd
