Yeah it sucks when the weld ends up partially in the bifocal and partially in the regular lens....and you didn't notice until you realize you can't really see all of a sudden.Poland308 wrote:I like a large viewing area in my hood, but I never realized till reading this that at some point I may need to draw sharpie lines dividing where I need to look when.
Bill Beauregard
- Bill Beauregard
Aging is not for the weak! I have always had an ongoing problem with fogging, something about nostril angle. My sons have always been very amused when I lay a nice bead parallel to the joint, but missing it entirely. The braille system doesn't help with welding. For fog, I have learned to cut a hole in a high end paper mask directing breath straight down, not flaring to the side.
Old people magnification is always a struggle. The old man focus issue didn't hit me until later than most. I was fifty. Now I'm never the optimum distance for my cheater to work perfectly.
No wonder old people are grouchy!
Willie
Willie
No the feeling well. I am north of 65.
I need tri-focals to see what I am doing and also have to wear safety glasses for work. I had a pair of work glasses made by my eye doctor. The work glasses are only bi-focals and only have the short and mid range lens in them. The idea is that while working, I really do not care if I can read the clock across the room but I do need to be able to see close up and three or four feet out. Cutting the eye glasses into three sections makes all three sections to small to be of much good and they certainly do not work under the hood. The Work Safety glasses work for most applications for me as I do not have to take them off to weld and when I need to grind, I just lift the hood and grind. Additionally, a lot of work sites require the welders to wear safety glasses while under the hood. As for the closeup lens in the safety glasses, they are not much good under the hood. Cheeters in the hood are a must.
Has anybody used the relatively new welding glasses sold by Miller?? I work in a lot of tight places and the hood often gets in the way. The Miller welding glasses look like they might help but they are expensive.
- Farmwelding
i love when that happens. Lift hood and look and see you missed your joint entirely or started curving but couldn't tell usually when I have a passive shade with the sunlight to my back.Bill Beauregard wrote:Aging is not for the weak! I have always had an ongoing problem with fogging, something about nostril angle. My sons have always been very amused when I lay a nice bead parallel to the joint, but missing it entirely. The braille system doesn't help with welding. For fog, I have learned to cut a hole in a high end paper mask directing breath straight down, not flaring to the side.
Willie
