If it's attached to a tractor, remove the toplink, get a couple of gorillas to help you lift the drag into a vertical orientation, then chain the drag frame to something on the tractor to hold it up. Then raise the 3 point to the highest position and you should be able to sit and work on the bottom tooth in the flat. Spin the thing like the wheel of fortune to move to another tooth.carthorse wrote: I'm thinking most of the welding is going to be vertical, I don't have anything big enough to move that thing so I can weld on the flat.
Lincoln Square Wave 200
Lincoln 225 AC/DC
Harris Oxy/Acetylene torch
Lincoln 225 AC/DC
Just checking back in. That was a big job! Mark - thanks for the idea for setting up the drag - of course my old tractor at home wouldn't start so my trusty flat bed was the fixture plate.
I ran a few test pieces and I didn't think that my little Millermatic had enough ass to weld all the joints on that 3/4" stock, so I bought a fair load of 7018 and practiced. A lot of the early welds were a bit dodgy looking, but by the end, it was going pretty well. I welded out all the out of position odds and ends with the Millermatic. It was maxed out and kept tripping the breaker but I learned a lot about flux core. Overall it was a great project - a lot of welding and consequently for me a lot of practice. Thanks again for everyone's help. I think my stick and Flux core skills are a bit better today than 3 days ago.
- File Nov 03, 20 07 48.jpeg (92.68 KiB) Viewed 1275 times
Don't forget to check out the dates on the last post before you reply. The last post was 3 years ago.
