Bevel the pipe and have a gap. You'll need a root face as well, make the gap the same as the root face
If you mean like this picture, I'd just set the pipe on flat and weld it.
- image.jpeg (21.48 KiB) Viewed 809 times
NO!! lolPoland308 wrote:I’m with Craig. Both of the other answers are correct, depending on pipe thickness and how you plan on stressing the finished product.
- there can be only one.jpg (11.03 KiB) Viewed 780 times
Thanks to all that replied. What I’m making is an adapter for a vibrahammer on a skid steer to drive 4 1/2” O.D.pipe. The wall thickness of the 6” pipe adapter is 5/16” I will weld it to the 1/2” plate and then weld a short 4” piece of 2 3/8”> .250 wall to the 1/2” plate that will go inside the cup of the hammer. Thanks
