It is currently Sat Feb 24, 2018 2:13 am Advanced search
Oxygen regulator
Oxygen regulator
Postby Farmwelding » Sat Jan 20, 2018 9:28 pm
So I've had my torch set for less than a week now and used extensively today. At around 9:00 this morning o realized my oxygen regulator was pulsing. After doing a little digging I read that it was most likely a bad diaphragm soni took it in and they gave a a brand new one. Last night I used the rosebud and it did one of scariest things I've ever seem or heard. Flickered on and of real rapidly due to the regulator and made my welding tip go nuts with the flame. Is this something common over years of wear or is it hit and miss. I've never heard of this problems till today. Still surprising that I've only had it a week.
Re: Oxygen regulator
Postby MarkL » Sun Jan 21, 2018 6:16 pm
If you have a check valve in the line you might try changing it as an experiment. I had a problem with my setup because I had a check valve and a separate flashback arrestor, the pressure drop across both of them was enough to make the gas flutter on and off at low pressures because it couldn't quite keep the spring on the check valve open. I can imagine the check valve spring getting into some kind of oscillation from the gas flow and causing the problem you describe, especially if you have more than one restrictive device in the line.
Lincoln Square Wave 200
Lincoln 225 AC/DC
Harris Oxy/Acetylene torch
MarkL
Postby aland » Sun Jan 21, 2018 6:35 pm
Nick,
I'm sure you're aware or familiar with regulatortorchrepair.com, but if not and you have a decent regulator, you can get it rebuilt for about $50 rather than getting a new one.
http://www.regulatortorchrepair.com/index.php
No affiliation, just a satisfied customer, they do good work IMO.
Alan
aland
Postby Farmwelding » Sun Jan 21, 2018 7:15 pm
aland wrote:Nick,
Alan
I bought it a week ago so they replaced it free of charge. I did take off the check valve and it helped but the new regulator had no problem with the check valve and has run fine so far.
Postby aland » Sun Jan 21, 2018 10:02 pm
Ah, didn't realize you bought it new, I thought you had bought it used... :oops:
aland
