c.schulz
    Wed Dec 14, 2011 10:14 pm
    Ortonville, Michigan
Can I buy and use a spoolgun to weld aluminum with my Miller 130XP MIG (110v) What would be the draw backs and then the plus's? I understand changing out the tank for Argon. Will this change the thickness that I can weld?
Thanks Chris
    Fri Feb 12, 2010 10:48 am
    YOUNGSTOWN, OHIO
You will need a miller 3035 spoolgun and an SGA 100 control box. You will be limited to probably 3/16-1/4 inch material, and that being with using a 50/50 helium argon mix. Check out this link.
http://www.millerwelds.com/products/wir ... ookup.html
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
c.schulz
Thanks for the info Jim. Did not realize about the helium/argon mix?? Tell me more as why helium?
Chris
    YOUNGSTOWN, OHIO
I could explain it, but this is better than what I could do. Not only that, I don't have to type so much. :D Check this out.
http://www.esabna.com/us/en/education/k ... uminum.cfm
If you have any more questions, feel free to pick the brains of the many very experienced and skilled weldors in this forum.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
