Mag
  • Mag
  • New Member
    Wed Dec 02, 2009 7:32 pm
I weld here in florida and i always have a fan on me while pipe welding smaw. Will the rapid cooling of my welds by the fan affect them ?
brian
    Sat Oct 03, 2009 10:11 pm
Negative. Maybe, if your welding Cast pipe. Black Iron though, No problem.
I agree with Brian, not a problem...its done all the time.
jody
Mag
  • Mag
  • New Member
thank you guys!
welder57
    Thu Jan 20, 2011 7:42 pm
only if you had flow on the pipe you were welding with stick. i use 6010 on natural gas under 125#, then go to 7018 for anything over that pressure because of the "HAZ" affect(heat affected zone)
