Gyoda
    Sat Dec 16, 2023 12:25 pm
Hi all,
Have my Lincoln Aspect 300 Tig welder and an inherited Coolarc 34 cooling unit.
The problem I have is wiring the two units: the aspect has a connector at the back but the coolarc which is older has two car type connectors and I have no clue how to modify it so it works.
Cooler is just a fan/pump with it’s pcb with relays…
Before anyone asks, yes I do have a water cooled torch to go with it.
Wires both in tig unit and cooler are black and numbered, only easy one to identify is the grounding…
Numbers inside tig do not match cooler numbers.
Browsing has been pretty unsuccessful
Any help would be super handy, usually weld ac at around 150 amps and the torch (non cooled) I am using does get pretty warm
Thabks in advance
