dseute
    Sun Jan 31, 2010 2:47 pm
How much should you open the cylinder valve on a propylene cylinder. I can't find anything in search engines, they just bring up stuff about Praxairs fire in St. Louis. This is for a welding class I'm taking, so if you could provide some references it would be appreciated. Thanks Darren
    Fri Feb 12, 2010 10:48 am
    YOUNGSTOWN, OHIO
You really shouldn"t open a fuel cylinder any more than 3/4 to 1 full turn. No need to open all the way. It's a safety issue.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
welder57
    Thu Jan 20, 2011 7:42 pm
absolutely no more than 1 turn. our company's safety manual specify's it as said by jpence38-in the event of a problem, it can be turned off quiclky
