450dualsport
    Wed Oct 30, 2013 10:46 am
I need to weld a new bung in to the bottom of my parts washer. If it is all cleaned out and the lid is open, would there be any sort of explosion hazard? The parts washer just contained regular cleaning solvent.
Thanks.
450dualsport wrote:I need to weld a new bung in to the bottom of my parts washer. If it is all cleaned out and the lid is open, would there be any sort of explosion hazard? The parts washer just contained regular cleaning solvent.
Thanks.
If it's clean, detached from the holding tank, and the lid is open, you have nothing to worry about. I assure you, the parts washer is not porous enough to hold dangerous quantities of flammables.
    Fri Nov 01, 2013 11:20 am
    Pittsburgh, PA
Just don't clean it with more cleaning solvent :)
450dualsport
Thanks. I feel better now!
It is one of those cheap 20 gallon washers with the flip up lid. It is clean and upside down on my welding table with the lid open. If you see a mushroom cloud over Canada, that will be me. :D
    Thu Jan 24, 2013 12:13 pm
Mostly if it has a large opening & a solvent that will dry off it's not a problem done with basic precautions - the ones that have caught me out are things with heavy oils like gear oil or 2stroke residue - small amounts of those in a hard to clean over looked area are capable of creating vapor when welding heat is near - then it gets to flash point & bang - enclosed things like exhaust pipes etc are favorite - when in doubt invert a CO2 cylinder & give the thing a nice quick blast of " snow " - as the CO2 warms up it will keep expanding maintaining an inert atmosphere - it's my go to method for fuel tanks - all the time you see a trace of " fog " coming out of an opening your golden.
450dualsport
I got it all welded up and I'm still here! :D
Interesting tip about the CO2. Thanks for sharing that.
olcarguy
    Thu May 22, 2014 11:47 pm
Job shop I used to work at we had an almost steady job repairing fuel tanks on the city buses. As long as the filler neck was open not a problem, once in a while you got a smoke ring blowing out with a little puff but nothing serious, I believe they ran furnace oil as fuel. Drained out as much liquid as would flow out, propped up on bench in a comfortable and welded down hand mig. good quick cash job.
“Good judgment comes from experience, and a lotta that comes from bad judgment.”
