    Sun Sep 22, 2013 10:14 am
    Minneapolis Mn 55407
Does any body use/know how the spot weld settings are used on Tig Machine?
What about this Eastwood kit?
http://www.eastwood.com/tig-spot-weld-kit.html.
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
Rick_H
    Sat Feb 08, 2014 1:50 pm
    PA/MD
That's an interesting idea....be easy to make yourself as well.
I'd assume its cranked up pretty high 150amps+ depending on material and thickness
    Sat Mar 30, 2013 11:49 am
    Sweden
I had a spot weld setting om my older GYS tig, meant more or less that up- and downslope was removed.
The idea is to clamp the sheets tight and hit it with high current so the first sheet melts and fuses with the second layer.
I found it easier to punch a hole and plug weld with a little bit of filler rod than finding the right setting everytime.
