So I have decided to use a rear shock from a mountain bike and build a 4 link suspension for my gate caster, some will say its over kill and going way to far but the tools are in the shop and I have the materials already do why not! Here are some shots of what I got done before thanksgiving took priority
Getting mocked in place
- ImageUploadedByTapatalk1417299841.691973.jpg (62.38 KiB) Viewed 1351 times
- ImageUploadedByTapatalk1417299829.238546.jpg (42.3 KiB) Viewed 1351 times
- ImageUploadedByTapatalk1417299815.044451.jpg (50.71 KiB) Viewed 1351 times
- ImageUploadedByTapatalk1417299802.959910.jpg (45.78 KiB) Viewed 1351 times
- ImageUploadedByTapatalk1417299790.579240.jpg (48.28 KiB) Viewed 1351 times
Jeep Cummins transplant specialist
I've been mocked in many places, but I doubt anyone will be mocking you...
Nice work, and as Jody has said, "There's no kill like overkill!"
Thanks!Otto Nobedder wrote:I've been mocked in many places, but I doubt anyone will be mocking you...
Started to weld
- ImageUploadedByTapatalk1417306793.581614.jpg (86.41 KiB) Viewed 1331 times
- ImageUploadedByTapatalk1417306783.601809.jpg (87.04 KiB) Viewed 1331 times
- ImageUploadedByTapatalk1417306771.995682.jpg (54.08 KiB) Viewed 1331 times
- ImageUploadedByTapatalk1417306754.188835.jpg (60.38 KiB) Viewed 1331 times
Neat. There's an old hot-rodding axiom which states, "If some is good, then more is better and too much is just right!"
Miller Dynasty 280DX
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
Victor Oxygen-acetylene torch
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
do you have a water table under the CNC?
i bought a GOTORCH 2x2 but I'm waiting
till we move to set it up.
in hind sight i should have bought the torch mate
Yep I do use a water tablemotox wrote:do you have a water table under the CNC?
How 'bout an actuator from an old "C" band satellite dish, preferably from a 14' or larger? 12VDC and adjustable limit switches and available at the junkyard for cheap? New linear actuators in that power range may cost a buck or three...motox wrote:now it needs a power opener
Nice and compact, and a careful design will give you a full 90* without much load since that caster will roll easy and keep the drag off the hinges.
Aluminum link inserts 3/8-24 thread
- ImageUploadedByTapatalk1417744203.603931.jpg (36.87 KiB) Viewed 811 times
- ImageUploadedByTapatalk1417744191.301712.jpg (47.45 KiB) Viewed 811 times
- ImageUploadedByTapatalk1417744179.477323.jpg (48.82 KiB) Viewed 811 times
- ImageUploadedByTapatalk1417744165.818052.jpg (45.51 KiB) Viewed 811 times
What is your opinion of the Smithy Lathes, thinking about getting one off their small 3 in one units. Currently free shipping and almost $1k in free accessories. I don't have any formal machining experience.dzljon wrote:I use a smithy 1324 granite lathe/millmotox wrote:logan Lathe?
I really like mine, opened a whole new level to mesoutthpaw wrote:What is your opinion of the Smithy Lathes, thinking about getting one off their small 3 in one units. Currently free shipping and almost $1k in free accessories. I don't have any formal machining experience.dzljon wrote:I use a smithy 1324 granite lathe/millmotox wrote:logan Lathe?
