Finally I found my problem.
Machine starts with a looong DCEP pulse which will ball a 1/16 electrode in just a few starts. Even a 3/32 melts off but not as bad.
This is one start with was a fresh 1/16 tapered with a flat point. The black spots are tungsten spatter
After 5 starts
Through a service shop I was told there is a switch behind the panel that could disable the DC start.
Pic speaks for itself, what an improvement that was.
Pics above was testing at 30 amps.
I have then tested with an almost flat 1/8 at 130 amps, no problem initiating the arc on oxidized aluminum.
Not affecting DC start either.
Pulse with pedal self-healed long before I tried this. Probably myself to blame for not pressing the button hard enough
