It is currently Fri Jan 19, 2018 11:10 am Advanced search
Square inside a Circle and some pulse tig settings
Postby admin » Mon Dec 05, 2016 10:15 am
playing catch up so here are the latest 2 videos
First one is on pulse tig settings for thin outside corners with no filler rod
Second video is some basic shop math for when you need to fabricate a square frame for a round part
Peace out,
Jody
admin
Re: Square inside a Circle and some pulse tig settings
Postby MosquitoMoto » Mon Dec 05, 2016 11:40 pm
Awesome! Thanks Jody.
The stainless/pulse video was just what I needed to see. I am about to undertake (another) exhaust in stainless and the mention of chill bars/blocks has me wondering. The exhaust I will be working on is oval in section so there is no way a square section bar would work.
I wonder if I just wrapped the exhaust on either side of the weld area with lots of tight layers of aluminium foil?
Kym
MosquitoMoto
Postby Rupes » Tue Dec 06, 2016 5:28 am
I'm about to start doing the same thing. I was thinking of solid core or even stranded copper wire and just wrapping it up to about 5mm from the joint.
I've had good results from manually pulsing via the pedal on corner joints in thin copper and SS. Haven't tried butt welding oval or round so not sure how much that warps. I have pulse on the welder just never really played around with it. Whats the biggest issues with thin tube, warping or blowing out?
Rupes
Postby Otto Nobedder » Tue Dec 06, 2016 7:03 pm
Somewhere here, a long time ago, this was discussed before. I'm not digging for it now...
I have scraps of 1/0 high-flex stranded welding lead that I can use to wrap thin sections with to serve as a heat sink, and it's made more effective if bedded in a heat-sink compound similar to this:
http://www.ebay.com/itm/N-W-30g-High-Pe ... rkt%3D1%26
To answer the other question, whether blow-through or warpage is the bigger problem, it depends on your level of experience. Starting out, blow-through will frustrate you first. Warpage is not quite the right term... Shrinkage issues will plague you. With stainless steel, I automatically assume a typical butt-joint in a straight run will shrink 1/16". However, when welding in a bend, such as the stock bends available for exhaust, the "short" side will shrink more. More accurately, the inner radius and outer radius will shrink the same, but the inner is a higher percentage of the linear distance, so the inside will seem to shrink more. If you fit a 90* elbow dead square to a straight section and weld it, you will end at around 92*, as an example. This shrink factor must be accounted for in the fitup.
Otto Nobedder
Postby HoodLyfe » Tue Oct 17, 2017 1:59 pm
ll
Sent from my E6782 using Tapatalk
HoodLyfe
Postby MinnesotaDave » Tue Oct 17, 2017 9:31 pm
Awesome videos :)
For burst tacking I switch my machine back to panel.
That way my foot control is just and on-off switch without having to move the whole range.
Just a small touch goes to full panel setting, click back off and done :)
...it'd be easier if I had a torch switch, but this works basically the same.
Airco 300 - Syncro 350
MinnesotaDave
Return to Video Discussion
