I'm pretty sure the "nuclear" kit is going to be a UV penetrant, rather than visible. Since it fluoresces under blacklight, much smaller traces are detectable, making UV penetrant quite a bit more sensitive. It's more expensive in several respects, though. First being the cost of the materials. Second, of course, is a powerful enough blacklight... A good 50W longwave will set you back $400 or so, and replacement bulbs for ours were $116 last time we bought. Third is the time and material to black out all light from your test area, if your piece is too big to move to a dark room.
On a side note, don't EVER blacklight anything in the company rest room... You do NOT want to see what glows in there... :lol:
I should add, I don't use UV penetrants at this time (we have the blacklight for oxygen-clean checks), as the visible is more than sufficient for what I'm testing.
dirtmidget33
    Tue May 13, 2014 5:22 pm
Well that would make sense however the dynaflux kit doesn't use UV light and it had same instructions for both. The only difference I found on the website for them is one is flammable and other isn't. They didn't list any other details on website which is while I enquired about it.
Here is link to kits on there site
http://weldingsupplies.dynaflux.com/vie ... eck-i-kits
Gonna try to get company I fix polaris housings for to spend money to use this stuff. I never thought about using it really, after watching Jodys video thought It would be a good idea to make sure we do get all the cracks. Have used machinst blue in past to help make some cracks more visible.
It may just have a few diferent ingredients to allow its use in a nuke plant. And it will have traceability for record keeping. Like batch numbers and such. They make a nuke grade duct tape too. The glue has a few diferent chemicals in it so that it is "approved" for use by the nrc.
A study of the MSDS for the two varieties shows the penetrant is the same in each kit. The developer in the nuke version is much higher in VOC, perhaps for a much faster dry time and much less residue to clean.
The cleaners are even more dramatic in difference. The non-flammable is methylene chloride, while the nuke version is essentially light Naptha.
In both cases, the "nuclear" is what I use. Sounds like marketing to me.
electrode
    Wed Nov 02, 2016 5:02 pm
I liked in the comments (you have to read) where the guy said:
Q:I cant buy that dye check where I live so I use kerosene mixed with food coloring in a spray bottle. for the developer, I use Dr. Shcolls athletes foot spray and it works great.
A: that sounds like something I would do.
I am definitely going to try that.
Looks worth a try if that is all you got. :D
