It is currently Tue Feb 20, 2018 11:32 pm Advanced search
playing with box cutter blades #razorbladechallenge
Postby admin » Wed Jun 28, 2017 11:01 am
admin
Re: playing with box cutter blades #razorbladechallenge
Postby Glowzinski » Wed Jun 28, 2017 11:25 pm
Very cool. I am teaching myself to weld. I have a Bobcat 250 and an AHP Alpha 200 tig. Can that thing go as low as the welder you are using? If not, after AHP gets their mig welder bag in and I buy it, I will have an excuse to buy another toy.
Glowzinski
Postby admin » Thu Jun 29, 2017 4:44 pm
Glowzinski wrote:Very cool. I am teaching myself to weld. I have a Bobcat 250 and an AHP Alpha 200 tig. Can that thing go as low as the welder you are using? If not, after AHP gets their mig welder bag in and I buy it, I will have an excuse to buy another toy.
The AHP Alpha 200 tig I used would definitely go low enough for box cutter blades.
Jody
admin
Postby Farmwelding » Thu Jun 29, 2017 9:12 pm
Only thing with the cheaper tig machines usually they have a very high start amperage and you will blow out the edge of the razor blade if you are not cautious. So if you use the aluminum block-use it to your advantage.
Return to Video Discussion
