Again,
Looks too cold for my taste.
I'll get my powermig set-up and show you my mig welds.
IMVHO, and my $00.2
~John
countryboy1127
- countryboy1127
Wow, 18ga.
I'm sorry.
I thought it was closer to 1/4.
If that's the case, WOW!!!!
I'm sorry.
Lolz, The extreme close up makes it look like Half inch plate. The weld must be tiny. Still buff off the scale though.
countryboy1127
- countryboy1127
Sorry guys let me correct myself its 3/16 . I posted the wrong pictures . You are correct ak good eye even looking at a picture lol
That is where the dime next to the weld helps to show actual sizeweldin mike 27 wrote:Lolz, The extreme close up makes it look like Half inch plate. The weld must be tiny. Still buff off the scale though.
- Wiredwelder
Very nice guys ! @jdiggs how did you get the part so clean without spatter ....I see very little, very impressed with the cleanness!
Using a wire wheel is cheating...just so you know....Wiredwelder wrote:Very nice guys ! @jdiggs how did you get the part so clean without spatter ....I see very little, very impressed with the cleanness!
It's the only way tho...
Gotta paint the parts anyway....
- Wiredwelder
I was expecting someone to say spray anti-spatter all over the place....that has never worked for me [WINKING FACE]
jwright650
- jwright650
Ok I'm a bit late to this party, but I have a totally different question about something in this picture originally posted by bluewave.
Are the radiused notches at the bend line of that plate put there on purpose? If so, what purpose does this serve in this fabrication?
Edit* see marked up pic below for clarification of my question
- fabrication.jpg (59.06 KiB) Viewed 653 times
John Wright
John,
I would guess it would be to prevent cracking often associated with forming thicker members. Or is can be a stress relief but I would go with the crack prevention.
jwright650
- jwright650
Ah, OK...I thought maybe there was something more going on that I was aware of....trying to advance my small knowledge base....LOLSuperiorwelding wrote:John,
There are some bend radii "rules of thumb" that apply to bending plate and when these radii are exceeded, I guess something like this would serve to mitigate the cracking issues.
We had bent plate (90°) attached to the top flanges of beams and it was used as pour stop for concrete floor slabs. Many times the outfit that bent these for us used too small of a radius in their press break for the thickness of plate. If we didn't have time to send them back to be redone, we had to carbon arc the outside radius of the bends to removed the cracks and weld them back up.
John Wright
