jeep534
    Wed May 07, 2014 8:10 am
what machine /torch are you using specifically what is the thumb switch on the torch and what is it used for.
I have been getting a lot out of the videos
thank you
archie
Linde ucc304 tig/stick
Hobart 300 mig
Lincoln 225 ac buzzbox
Smith Versa Torch OA Rig
Full Manual Machine Shop
    Tue Jan 07, 2014 9:06 pm
    Elizabeth, WV
I cannot speak for the machine itself and torch but the switch looks the same as the one on my Everlast machine. That switch can be used instead of the foot pedal and is basically an on off switch like on a mig gun. You set your amps where you want them, push the button in to start the arc and when you let off of the switch it stops. Some of the switches have adjustments on them but that one looks the same as the one on my torch so it is just an on off switch. Obviously Jody can answer it for you but that is my observation.
Matt
yep, its a switch just like on everlast machines. When the metal is thick enough, its pretty easy to guess an amperage and then just set a couple of seconds of upslope and downslope time....and with zero upslope , its handy if you have to do lots of tack welding where you are dragging your pedal around something
best,
jody
