It is currently Sun Feb 25, 2018 9:44 pm Advanced search
1/16 electrodes for stick
Postby sedanman » Sun May 29, 2016 7:02 am
How about thin gauge steel or even stainless with 1/16 electrodes? Even use a 120 volt inverter source. Apologies if it's already out there but l couldn't find anything.
sedanman
Re: 1/16 electrodes for stick
Postby Poland308 » Sun May 29, 2016 8:22 am
I ran a little no name 110v inverter the machine and the leads only weighed about 10 lbs. think it maxed out on the dial at about 80 or 90 amps. But even then it had trouble keeping a 3/32 6010 lit. It would run 1/16 though. Then I used 3/32 7018. Used it quite a bit actually.
Postby ryanjames170 » Sun Oct 16, 2016 11:12 pm
i would have to second the 1/16 electrode idea.. i mean there out there but i evan am not overly sure how u would go about welding with them on thin stuff..
Welder/Fitter
RM Fab & Products
Miller 2E DC Welder Generator
Everlast Power IMIG 200
Everlast Power ARC 200ST
Hobart "Auto Arc" 130
Hobard Oxy Torch using propane.
ryanjames170
Return to Wish List
