It is currently Mon Apr 24, 2017 1:23 am Advanced search
Tig arc will not hold and cuts out at low amps.
Postby Danylo66 » Mon Apr 10, 2017 10:24 pm
After welding for a half hour all of a sudden by tig welder will not hold an arc at low amps.
Its frustrating.
Has anyone experienced this problem?
Checked my ground checked and replaced my tungsten adjusted the gas. Pulled my hair out and cried.
:oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :cry: :cry: :cry: :cry:
Danylo66
Re: Tig arc will not hold and cuts out at low amps.
Postby Danylo66 » Tue Apr 11, 2017 2:15 am
Waiting on an answer from Everlast. Maybe something is out of sinc.
Danylo66
Postby LtBadd » Tue Apr 11, 2017 4:52 am
What amperage are you welding at, and what size tungsten are you using?
To avoid criticism, do nothing, say nothing, be nothing...sounds boring to me
LtBadd
