    Thu Dec 26, 2013 12:41 am
    Laredo, Tx
Time to let this go. It's been pretty good to me for over 5 years. Still works great. HF start can be finnicky but usually I attribute it to having a crappy ground connection. I always had to make sure it had a very good ground or otherwise the HF start just wouldn't. Rated to cut 3/8", and it will, but leaves a lot of slag. 1/4" is where the clean cutting stops at. Will severance cut 1/2" not too badly. Give it 110psi of clean dry air and watch out for those sparks!
Package includes:
  • Qty:1, Eastwood Versacut 40A dual-voltage plasma cutter
  • Qty:1, Ground clamp with longer cable
  • Qty:1, plasma torch
  • Qty:1, 6-50R to 5-15P adapter for use on 120V
  • Qty:14, long electrodes (for use with the long pipe tips)
  • Qty:18, long pipe tips
  • Qty:17, standard electrodes
  • Qty:7, short pipe tips
  • Qty:1, standard tip
  • Qty:8, diffusers
  • Qty:2, cups
$325 shipped in the 48 CONUS, so long as shipping doesn't run over $59.99 to your location. Item will go in a heavy duty Lowes shipping box with bubble wrap, USPS or FedEx. Check/MO preferred.
Oh, and it works just fine on a 7kW generator, but it's even more picky about ground cleanliness. So long as you keep the arc length within 1/16", it will work just fine.
