FS: Fronius Magic Wave 2500 TIG / MMA welding machine
Posted: Fri Feb 19, 2021 8:10 am
by h7m1
For sale is a used water-cooled Fronius Magic Wave 2500 TIG / MMA welding machine including the FK 2500 cooling unit, in excellent working condition with no issues at all with it.
The robust construction of the welding machine makes it an all-rounder and is therefore suitable for every application.
https://i.imgur.com/2pjN03E.jpg
Technical specifications:
Fronius welding machine
-DC (suitable for steel, stainless steel, duplex, copper, etc.)
-AC (suitable for aluminum)
-Weight about 26.6 kg
-250 A
-Job operation
-HF ignition (contactless ignition)
-2 and 4 cycle operation
-Earth fault monitoring
-Gas test function
-Automatic cooling unit shutdown
-Digital display
- Carrying strap / handle
-Duty cycle 100% -180A - 60% -210A - 40% 2450A
-Dimensions H / W / L 435mmx250mmx560mm
- Mains fuse 16A.
Fronius cooling unit 2500 FK
-Weight about 9 kg
- Delivery rate max. 3.5 / min
-Dimensions H / W 225mmx240mm
-Coolant content 4l
It comes complete with all that is listed.
Welding machine
-Cooler
- TIG torch
-Electrode holder (MMA)
-Ground cable
-200 bar pressure reducer.
Asking Price:USD$4500
If you are interested kindly send me a messsage,
equipments at protonmail dot com
Thank you for your time.
Re: FS: Fronius Magic Wave 2500 TIG / MMA welding machine
Posted: Wed Apr 07, 2021 6:32 am
by h7m1
This is still available for sale
Posted: Tue Mar 21, 2023 1:45 am
by h7m1
A reasonable offer will be accepted.
