You flip flopped a couple of lines. The one hooked to your water outlet is your gas line that's why you have water coming out the cup. Do they use the same size threaded fittings on all three hoses?
- Farmwelding
Don't remember exactly what video by to know Jody did something similar and had to wash out his lines Ti to make sure to clean the lines for normal welding. I'll try and find it.
on a normal torch the gas goes thru the power line.
For the water-cooled torch you run the water return thru the power line. Gas and cold water thru the two separate smaller hoses, you already figured out which one is gas .
