cjhorch
    Mon Feb 02, 2015 8:01 pm
I'm at the drawing board working on a new project. I'm using an old aluminum ramp from a u-haul truck. I'm working with a Ironman 230 and looking for information on what type of aluminum the ramp might be made of and what type of wire I should use?
motox
    Thu Nov 28, 2013 12:49 pm
    Delaware
welcome to the forum.
i do to mig weld aluminum
but I'm sure someone will chime in
if you are patient.
Artie F. Emm
    Thu Jul 24, 2014 7:53 am
Welcome to the forum!
For full disclosure, I have not welded aluminum with MIG, altho I know enough to tell you your machine is *capable* of aluminum MIG but may not be *ready* yet. Apologies in advance if you already know that aluminum wire does not behave like steel wire: it is too soft to push through a cable to the MIG gun, so to weld aluminum you'll likely need a spoolgun, which holds the spool of wire so the wire travels 8 or 10 inches to the contact tip instead of 8 or 10 feet.
Also, for aluminum MIG you'll need pure argon gas for shielding, rather than argon-co2 which is common for steel.
So again, sorry if you knew all that stuff already. Do you MIG weld steel now?
Dave
aka "RTFM"
Mike
    Mon Dec 06, 2010 1:09 pm
    Andover, Ohio
Welcome to the forum.
M J Mauer Andover, Ohio
Linoln A/C 225
Everlast PA 200
    Tue Aug 19, 2014 2:34 am
    Short Creek, Arizona
Greetings and welcome.
Miller Dynasty 280DX
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
Victor Oxygen-acetylene torch
