If you decide on a chop saw the "Carbide-tipped blade" saws, although more expensive, are superior to the abrasive blade saws. I have a Makita LC1230 that I recently used to build a pipe fence around some properity I own. It cut 2" sched 40 pipe like it was butter and very accurately.
http://makitatools.com/en-us/Modules/To ... ame=LC1230
Dynasty 200DX
MM252
Powermax 45
VTS 450/460 Oxy-Acetylene
MM252
Powermax 45
That Evolution saw did all the cutting on This welding cart......
Thanks, it turned out ok.LtBadd wrote:Now that's quite the welding cart, well done!AKweldshop wrote:That Evolution saw did all the cutting on This welding cart......
- IMG_9916.JPG (55.21 KiB) Viewed 2367 times
- IMG_9890.JPG (102.66 KiB) Viewed 2367 times
- IMG_9921.JPG (102.25 KiB) Viewed 2367 times
- IMG_9931.JPG (83.77 KiB) Viewed 2368 times
- IMG_9928.JPG (54.19 KiB) Viewed 2368 times
- IMG_9935.JPG (94.94 KiB) Viewed 2368 times
- IMG_9938.JPG (105.27 KiB) Viewed 2368 times
- IMG_9940.JPG (102.58 KiB) Viewed 2368 times
- IMG_9941.JPG (50.32 KiB) Viewed 2368 times
- IMG_9717.JPG (86.25 KiB) Viewed 2369 times
- IMG_9716.JPG (69.13 KiB) Viewed 2369 times
- IMG_9712.JPG (91.35 KiB) Viewed 2369 times
- IMG_9360.JPG (117.74 KiB) Viewed 2284 times
- IMG_9359.JPG (76.01 KiB) Viewed 2284 times
- IMG_9718.JPG (75.77 KiB) Viewed 2284 times
- IMG_9361.JPG (83.94 KiB) Viewed 2282 times
- IMG_9364.JPG (111.85 KiB) Viewed 2282 times
- IMG_9368.JPG (109.12 KiB) Viewed 2282 times
- IMG_9369.JPG (115.28 KiB) Viewed 2280 times
- IMG_9374.JPG (101.58 KiB) Viewed 2280 times
- IMG_9376.JPG (61.29 KiB) Viewed 2280 times
- IMG_9381.JPG (76.5 KiB) Viewed 2278 times
- IMG_9380.JPG (108.71 KiB) Viewed 2278 times
- IMG_9377.JPG (67.86 KiB) Viewed 2278 times
- subwayrocket
I have the DeWalt DW872 saw . It's decent . I tried an evolution blade and it started loosing teeth. If you're gona spend 4-500 , ask around about the Morse saw , I think it's just a little bit more but may be better . The base on the Dewalt although better than flimsy ones at harbor freight, it's not as thick as i'd like . The clamping mechanism is decent . It's a good saw for the money ...looking back I think I would have gotten the Morse . As for the abrasive saws, I went thru two of them. The second one was a Dewalt, it burned out after only about 20 cuts, sparks shot out the motor vents. I got a Rigid R41421 and it is a very solid, very good abrasive saw. I don't use it much since the DW872 . Good luck
I just bought the IronTon. The price was right. $299 out the door with free shipping from Northern Tools. I haven't really started using it much. I made two cuts with it on piece of steel a friend gave to to weld on a post for him. It seems to cut pretty good. The cuts but up pretty nicely. I wouldn't say amazing but for $299 not a bad buy. The base seems heavy enough and the clamp seems ok for what I will be using it for.
- IronSaw.jpg (54.03 KiB) Viewed 2106 times
- Cut.jpg (85.74 KiB) Viewed 2106 times
Kriky
Hobbiest
Everlast PowerTig 210EXT
Hobbiest
I just recently purchased an Evolution EVO380. Got it for under $400 at my LWS. Worth every penny. As to the poster who questioned if the 380 is worth the extra money I would say yes. It's just a much more solid machine.
A lot of guys like Makita saws, see reviews. However I personally don't like pistol grip on this type of saw, just a personal preference.
