It is currently Tue Feb 20, 2018 5:32 pm Advanced search
Carbon arc gouging
Re: Carbon arc gouging
Postby Farmwelding » Wed Sep 20, 2017 2:46 pm
Last night I did my carbon arc gouging and found out just how easy and annoying it really is. Took a layer off a boat anchor and then he wanted a bunch of 3/8" plate cut from practice weld test to not waste material. Did a few with carbon arc gouging and the rest with the torch.Just glad it was that easy.
Postby weldin mike 27 » Wed Sep 20, 2017 5:15 pm
If it was loud, dangerous, annoying AND hard, no one would do it, Because it's so easy (in the hands of a trained and competent operator), that's why its still widely used.
weldin mike 27
Carbon arc gouging
Postby snoeproe » Sun Dec 24, 2017 8:29 am
Carbon arc is not a dying process. Outdoor maintenance work on heavy equipment is one place where it's still heavily used. Sure, you could use oxy fuel torch to remove all the wear plates from an excavator bucket, (you could also use a 5" angle grinder if you wanted) but arc air does it way faster with better control. The job is sped up and costs for the repair are reduced.
We've used arc lots on large structural steel jobs too.
Arc air is my preferred method for steel removal.
snoeproe
Previous
Return to Metal Cutting
