kermdawg
    Tue May 25, 2010 8:16 pm
That baleigh looks like the same one I was lookin at. Differant web site though. Still cant find the site I was looking at before. Little cheaper too :)
Wobulate
    Fri Oct 15, 2010 1:30 am
    USA
kermdawg,
I found this today.
http://www.coldsawstore.com/sawblevma.html
Hope this helps.
Wob
WOB
Lincoln,Precision TIG225
Miller,Millermatic 251
Miller,Spoolmatic 30A
Miller,Millermatic 130XP
Miller,Spectrum 625
Miller,Thunderbolt 225AC
KMG,Belt Grinder/2x72
Ingersoll Rand,Compressor/5HP
sschefer
    Wed Aug 18, 2010 7:44 pm
If you're a non production do-it yourselfer then a 12" dual compound mitre saw with the Freud ferrous metal and non-ferous metal blades work pretty well. Repeatability is good enough if you build a fixture. These saws won't last long in a production shop because the motors are not totally enclosed fan cooled (TEFC) and eventually metal dust an chips will get in to it and short it out. TEFC Motors and blade speed is basically the only difference you'll find in a metal vs. wood vertical bands saws. Horizontals are a different story and have their uses but are becomming less popular now that the problems with dry saws, (except heat) are sorted out. A wet saw has special space and plumbing requirements that only serious shops are willing to invest in but it is the ultimate solution for speed, accuracy, repeatability and controlling the cut edge heat affected zone.
Regarding the dual compound vs. single.. If you're whacking away at a 25' piece of t-bar it's really nice to not have to flip either the material or the saw every other cut when the cuts are beveled or as was my case when I became enlightend, compound mitered.
kermdawg
Holy hell, that'll save me from buyin a whole new saw! I already got a single bevel miter saw at my house that my brother gave me cause it was froze up (all it needed was some good old WD40 and some TLC). Imma go buy one of them blades at homey depot and try it out when I get home later in the week.
As far as Band saws go, I'm so used to a portaband I couldnt think of usin anything else (less your in a production shop or somethin). Cheap, easy to use, go anywhere, cut damn near anything. Im just tryin to find a good price on one, sein as how my bud got one at the pawn shop for 100 bucks I cant justify spendin 400 on one. Throw in a couple pipe vises and your good for all the small stuff.
metlcre8or
    Thu Feb 24, 2011 2:06 pm
I have a 90-tooth TCT blade. It didn't work well for cutting 304 Stainless. I haven't used it for much else beyond Aluminum.
--Bill the metal creator
kermdawg
While on the subject of cuttin metal-A while back I had a job that required me to drill a hole bout 1-1/2 in a stainless steel sink. No prob, done it hundreds of times. Only this sink was 18 guage. Had a brand new hole saw and arbor bit, and it destroyed both of em. I did my best to keep em cool while I was drillin too, only drilled about 10 seconds at a time and let the heat cool down before I resumed.
Any suggestions for drilling through the thicker guage stuff? Only think I know of is those electricians punch/knock out sets, but they are expensive :(
Try the Milwaukee brand bi-metal hole saw. Every now and then I have to put a 2" hole through 7/16 304 SS and the Milwaukee has given me the best results so far with the money the company is willing to spend. I've gotten as many as three holes from one saw.
The ideal cutting speed is 50 RPM, so a variable speed drill, preferably w/ gear reduction, is a must, and at low speeds you'll have to let the drill cool more than the saw. I cut dry (no oil) and if the cut depth gets close to the tooth height, you have to lift often to clear chips.
Steve
kermdawg
Thats the one I used. I dont know the rpms of my drill though. I think the low setting is around 150 or so, and the higher setting is 1500. I use the high setting for the pilot and the low setting for the actual drilling.
I did not have gear reduction on mine though. I guess next time I need to drill one Ill borrow a buds right angle drill.
I find low RPM and a lot of pressure, like in a drill press, works well. In the thin section you're cutting, heat buildup, as you mentioned, is your enemy. Is it possible to make the cut under water?
Steve
kermdawg
Well not entirely no. I have found using some oil helps though, just didnt have any on me at the time.
Im gonna research the alloy of that sink to find out what kind of SS it was, cause I've never seen a piece of metal do this to a holesaw before.
edit-looks like its 304. Still never had this problem before :( oh well. I think I'm gonna try to invest in a hole punch kit.
Wobulate
    USA
To All,
The carbide tipped blades for the Multipurpose Cut saw are expensive (150-200). :(
The saws (brand name) can run 400-600.
Instead stick with a Portable Band Saw (like the Milwakuee deep cut (4-7/8") 299.
Blades are around $7.00 each, or cheaper if you shop. 8-)
Then add a Band Saw stand from Swag Off Road.com and turn it into a vertical band saw with a miter gauge. The saw can be installed and removed from the stand in about 20 seconds. Just another path you might consider.
WOB
WOB
Miller,Spectrum 625
kermdawg
Hell Jody had a video a couple weeks ago on buildin one of those porta band stands yerself for like 20 bucks I think it was, and it was trick you could customize it however you wanted.
Ya I would like a portaband too :)
Wobulate
    USA
kermdawg wrote:Hell Jody had a video a couple weeks ago on buildin one of those porta band stands yerself for like 20 bucks I think it was, and it was trick you could customize it however you wanted.
kermdawg,
I did see the stand in the projects directory, it was very simple and useful. But you really can't compare that stand to the one from Swag Off Road.
Take a look at their web site (http://www.swagoffroad.com) and read how it is constructed, you will see that this is a heavy stand providing a stable platform for sawing. SOR also offers an optional miter gauge track and a simple but effective on/off switch (most likely from Harbor Freight).
Troy, who owns SOR is a Mechanical Engineer, and his product designs are evidence of his capability to see a need and build a solution.
Check out their web site, I know you will be impressed.
Wob
WOB
Miller,Spectrum 625
kermdawg
Those plates gave me wood. 1-1/2 thick forged steel. mmmmmm
BulldogSV650
    Fri Jul 08, 2011 2:27 am
How about the Rage Evolution range??
I have one of their mitre saws. Mainly used on wood, but it is fitted with multi-purpose blade that cuts steel too. The mitre blades are rated for only a couple of hundred cuts on steel, but they do a specific chop saw that is rated for a thousand cuts. They are a lot cheaper than the name brands so might interest a hobbiest or small business.
http://www.evolutionpowertools.co.uk/uk/index.html
Check them out. I'm happy with mine and cost me less than half price of a name brand single purpose mitre saw. Replacement blades on the mitre saw is around £25 last time I checked. Still need to use it more with steel so will see how long the blade lasts.
Clint.
kermdawg
We must be lookin at somethin differant, cause the replacement blades for the chop saw i was lookin at on there were 120 bucks, plus shipping. Ouch :(
http://www.evolutiononlineshop.com/stor ... 20Saw%202/
BulldogSV650
Sorry was only checking the multi-purpose blades. They are the only ones supplied by my diy supplier.
http://www.screwfix.com/p/evolution-mul ... 55mm/57380
I was mainly checking the 255mm blades.
http://www.screwfix.com/p/evolution-rag ... 55mm/65166
Doesn't look like they supply the steel only blade as they mainly supply the building trade.
Just tried to see if I could buy a steel only blade from the website. When I selected the UK it didn't give me the option of the steel range. Only multi-purpose blades. Bummer can't give you a comparison in pounds..
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
Hi there,
Anyone know if I can take the abrasive blade off my drop saw and put one of these TCT blades or similar or are they completely different machines?
Humour Me
Wobulate
    USA
weldin mike 27,
Hi there,
Humour Me
Abrasive chop saws operate around 3,600 RPM, the Dewalt DW872 Multi-Cutter Saw operates at 1,300 RPM.
The abrasive blade will not work.
Wob
WOB
Miller,Spectrum 625
    Australia; Victoria
Hey,
Thanks for that mate, I realise that now. I shall have to buy both.....damn, wife will be pleased. :lol:
michialt
    Thu Jan 24, 2013 3:36 pm
I use pretty much that exact saw. Right out of the box it was a few thousandths off from being square, After an hour or so of adjusting/cutting/measuring and the repeating I got it to about 5/1000 on 90 degree cuts, and around 12-15/1000 on 45 degrees. I don't do too many other angle cuts.
One thing I have noticed though is that it will occasionally wander off from square. It's not a lot, nor is it frequent (maybe 3 times in 6 months). I usually just fix the error with the grinder when I first notice it. But I always check before I start a project where I cut a lot of pieces before assembly.
I use mine on square/round/angle mild steel, 4041 Steel and 6061 Al. I don't know what I would use other that this saw.
MillwrightRWG
    Sun Jul 07, 2013 8:16 am
I have a older Mikita 12" cold cut love the saw for miter cuts on square tubing and round ,but it taught me some pricey lessons
Does not like being pinched ,I figured it didn't but learned some heavier bar stock and some heavier tubing has some stress built in that will pinch those blades and teeth come off . Also used the circular saw version before I had my plasma cuter.
It was used for cutting 11ga sheet steel better than torch or gas saw but threw it out after getting the plasma I hated the chips the saw caught most of them but my knee caps got some too . And never cut on sheet steel that had been heated (torch cut or welded on ) even a little could pinch the blade . Best blades I think were called Bad blade they made 12" and 7.25" performance was good and they were cheaper ,but can't find them local any more
arc54
    Sat May 19, 2012 8:47 pm
I have the dewalt multipurpose 14inch saw your talking about, I just last week had to get the blade sharpened it was about 30 bucks at my tool warehouse. The blades are expensive but the do last a while(I mostly cut 45 degree angles in 1/8th wall square tubing). I recently bought a second blade as a backup and made the mistake of buying a non-resharpening blade for 130.00 :(
So just be careful with the blades you buy. I am now ordering a new blade that can be resharpened as a backup.good luck I hope this helps Steve
