It is currently Mon Feb 19, 2018 1:55 pm Advanced search
how to cut 16 gauge sheet metal
Postby burnttoast » Tue Jan 23, 2018 12:06 pm
Hello all, wondering if anyone can help. I'm doing a small artsy project and need advice on how to cut out a cat silhouette
that measures just 4x5 inches. as per the title, the gauge is 16. I can use my angle grinder to remove the large pieces of metal that I don't need, but what can I do to get closer without cutting my fingers off. thanks
burnttoast
Re: how to cut 16 gauge sheet metal
Postby AndersK » Tue Jan 23, 2018 12:28 pm
This type of electric shear can cut quite narrow curves.
For a non daily use the Harbour Freight version do well, at least if you rough cut first.
https://www.boschtools.com/us/en/boscht ... s-23498-c/
AndersK
Postby motox » Tue Jan 23, 2018 6:27 pm
Matita 1602 electric shear
i own one its a great tool
motox
Postby clavius » Tue Jan 23, 2018 10:06 pm
If you only have one (or a few) to do a decent variable speed jig saw with a fine metal cutting blade will make reasonably quick work of it. You can cut pretty tight curves with it. Just support the work well, take your time and wear hearing protection as the sound is quite obnoxious.
If you don't own one already something suitable is reasonably affordable and has lots of other uses.
clavius
Postby Graveyard » Fri Jan 26, 2018 8:43 pm
I use a Dewalt DW892 shear as well as a dewalt 893. Both are pricy but a worth while investment if you are planning on doing a lot of cutting. I’ve had the DW893 for two years now and it has been great only had to rotate the blades once. It has 4 cutting edges on the blades. The DW892 only has one cutting edge so when the blades are shot you have to replace them.
Graveyard
Postby snoeproe » Sat Feb 17, 2018 6:34 pm
My Cnc plasma table will quick work of that job.
snoeproe
Postby snoeproe » Sun Feb 18, 2018 9:57 am
The quickest way to cut sheet metal is with a plasma cutter.
snoeproe
Postby Homemade » Sun Feb 18, 2018 1:10 pm
Plasma... why stop there? Go straight to water jet. No warpage.
Homemade
Postby metalman21 » Sun Feb 18, 2018 1:33 pm
clavius wrote:If you only have one (or a few) to do a decent variable speed jig saw with a fine metal cutting blade will make reasonably quick work of it. You can cut pretty tight curves with it. Just support the work well, take your time and wear hearing protection as the sound is quite obnoxious.
This is a reasonable way to get it done. Use some 2" rigid foam insulation board under the metal on the bench to back it up so you don't have to hang the blade off the edge of the bench. Just make sure the blade isn't too long and stays within the thickness of the foam. I keep some foam panels around for doing this when it's my only option. Works with the router also.
When the foam gets beat up, toss it out, doesn't cost much.
Ernie F.
metalman21
Return to Metal Cutting
