I looked long and hard, but I couldnt find the tct angle grinder blades I took of my last job(i wanted to take a pic of them).....hmmm.
I don't know where to buy them, since my employer bought them.
Sorry
rickbreezy
- rickbreezy
rickbreezy
- rickbreezy
did about 75 cuts or so with the norton blade on friday, 2 through 2" 1/4" wall sq tube. as long as you keep dressing the edge, it keeps cutting. I might try some cutting wax if I remember to pick some up at the welding supply. I think I've burned up about 3/8" off the blade so far. not bad for $4.
Food for Thought,
Are you sure the TCT blades are for a chop saw?
The speed of a 14" Abrasive Chop Saw is between 3600 and 3900 RPM (Milwaukee=3900).
There is another type of chop saw called a dry cut saw that uses the TCT blades exclusively.
The speed of a 14" Dry-Cut Saw is between 1400 and 1600 RPM (Milwaukee=1500.
They use 72 or 90 tooth TCT blades.
Wob
Wob
WOB
Lincoln,Precision TIG225
Miller,Millermatic 251
Miller,Spoolmatic 30A
Miller,Millermatic 130XP
Miller,Spectrum 625
Miller,Thunderbolt 225AC
KMG,Belt Grinder/2x72
Ingersoll Rand,Compressor/5HP
Miller,Spectrum 625
