AFR_Autoworks
    Mon Nov 30, 2015 2:35 am
    Red Deer, Alberta, Canada
So I am going to be working with titanium a little bit now. Just curious what people use to cut it? I have a water cooled bandsaw that I will be using. I am mostly curious on the blade choice. Also, what would be considered acceptable to de-bur/ prep the edges? Is a zirconium sanding belt ok or should I be looking into something else?
    Fri Nov 01, 2013 11:20 am
    Pittsburgh, PA
I saw one MFG advocating zirconia belts for titanium, and another saying that their aluminum oxide belts are good for titanium. I'll ask my buddy Alex (BPAutosports) and see what he has to say
AFR_Autoworks
Thanks! I know I need to get a different blade for sure. The tooth count is WAY too low on the saw I bought. I actually follow him on Instagram haha.
    Pittsburgh, PA
His response: I use the same belt for everything, no need to switch
AFR_Autoworks wrote:So I am going to be working with titanium a little bit now. Just curious what people use to cut it? I have a water cooled bandsaw that I will be using. I am mostly curious on the blade choice. Also, what would be considered acceptable to de-bur/ prep the edges? Is a zirconium sanding belt ok or should I be looking into something else?
The blade choice would be determined by the thickness of the material, is it flat bar, pipe, tube...?
