Stick_Welder_Steve
    Sun Nov 08, 2015 6:39 pm
I currently use a hitachi 4 1/2 inch grinder with dewalt discs. Not the best brand, 1 disc only lasted me about a week. Any good brands that last a decent long time would be much appreciated!
Norton or Weil both make good wheels. I think they make them for most of the big names. How long a disc or wheel last usually depends on using the right grit and kind for the job your doing as well as how you use it. I stock flapper wheels in 40-60-80 grit on my truck as well as hard wheels 1/4 - 1/8 -3/32 in thick.
ex framie
    Sun Aug 09, 2015 1:09 am
    Brisbane QLD Land of oz
Pferd.
Pete
Stick_Welder_Steve
Poland308 wrote:Norton or Weil both make good wheels. I think they make them for most of the big names. How long a disc or wheel last usually depends on using the right grit and kind for the job your doing as well as how you use it. I stock flapper wheels in 40-60-80 grit on my truck as well as hard wheels 1/4 - 1/8 -3/32 in thick.
Have you ever used sait grinding discs? I heard from a friend that they work really well
Stick_Welder_Steve
ex framie wrote:Pferd.
Haha I dont understand, is that a brand for grinding discs? :lol: :lol:
Yes Sait and pferd. The shop I work for buys in bulk. They buy from all those big names. I don't notice much diferance between brands but I rarely use thick wheels it's mostly flapper wheels and the 3/32 and 1/8 in thin wheels.
    Wed Oct 23, 2013 3:30 pm
    Palmer AK
Norton, Dewalt and Metabo for me.
    Sat Aug 01, 2015 8:38 am
    The Land Down Under
For me it's often Flexovit.
Mostly because that's what Bunnings sells and they are nearby.
Kym
    Thu Jan 24, 2013 12:13 pm
Like many buying their own consumables I tend to buy on price / locally available - but I have used Smith & Arrow on occasion - they last well compared with anything else I tried.
-ViO1QN9RlE
iwwsRbZbaIg
Stick_Welder_Steve wrote:I currently use a hitachi 4 1/2 inch grinder with dewalt discs. Not the best brand, 1 disc only lasted me about a week. Any good brands that last a decent long time would be much appreciated!
Brand names aside, having the right disc for the material (stainless, aluminum?) is the real issue here, find a brand that's good, (many mention above) and ask your LWS or call the manufacturer to know which is the best for the material you'll be grinding.
    The Land Down Under
Slightly off topic but here goes, this might be useful to someone:
Best grinding lesson I've learned I picked up from a magazine years ago. There was a feature on a home workshop. The guy had four angle grinders hanging up. His advice? "Grinders are cheap. Rather than endlessly swapping discs during a job, I just have a grinder for each job. Cutting, grinding, wire wheel, flap disc."
I've never regretted buying an extra grinder. Put one down, pick up the other, keep moving.
Kym
Stick_Welder_Steve
AKweldshop wrote:Norton, Dewalt and Metabo for me.
Can Norton brand discs be found in local big box stores like home depot or do they have to be ordered online?
Stick_Welder_Steve
I go to a trade school so we dont do much as far as exotic metals go mostly just carbon steel, aluminum, and stainless.
hey_allen
    Thu Mar 05, 2015 6:09 pm
    SW Oklahoma
MosquitoMoto wrote:His advice? "Grinders are cheap. Rather than endlessly swapping discs during a job, I just have a grinder for each job. Cutting, grinding, wire wheel, flap disc."
Kym
I have been doing the same thing for years. I found a grinder at a hardware store on sale, since it had been the floor demo model and some sticky fingered idiot had pocketed the grinding disk locking nut and washer. Makes a great wire wheel mount!
-Josh
Greasy fingered tinkerer.
nickn372
    Sat Jan 28, 2012 11:35 am
    Sugarcreek, Ohio
I too buy what the LWS has. I also will watch for deals on brand names like Dewalt at tractor supply and rural king. Sometimes you find really good deals on old stock cutting wheels etc... for real cheap in their bargain bins. One brand I really like that is mostly available only through the Internet is Klingspor.
Be the monkey....
Stick_Welder_Steve
MosquitoMoto wrote:Slightly off topic but here goes, this might be useful to someone:
Kym
I remember my instructor notifying me of the small trick and I have never regretted it once, the ability to quickly switch between different discs quickly is amazing
ex framie
Kym
Not long ago my 26 yr old hitachi grinder died, if I had been smart enough to have checked the brushes and changed them it would still be running.
Anyway down to the hardware store for a replacement, same make, same size, same output grinder was on special for $50, I bought 2 (the original was $85, in 1989).
Several weeks later during a project, I was getting sick of having to change discs/brushes, back to the hardware store, bought 2 more hitachi grinders, same size with higher output for less than $60 each, so I now have 4 100mm + 1 7 1/2 inch for bigger jobs.
Yep all the new ones are made in china, but they seem well made.
Saves a lot of stuffing around changing disc types.
Now just have to build a mount to keep them on.
Pete
    Palmer AK
Not sure. I got mine off eBay.
    The Land Down Under
[/quote]
Now just have to build a mount to keep them on.[/quote]
Another benefit of this approach is that even if you are buying 'budget priced' grinders, because you have 3 or 4 grinders sharing the work, they tend to last okay.
I welded up hooks for my grinders. I have cable tie loops on each grinder and I just hang them from a shed rafter.
Kym
hey_allen
    SW Oklahoma
ex framie wrote: Now just have to build a mount to keep them on.
I'm not affiliated with these guys at all, but had seen this a bit back over on one of the offroad wheeling forums.
Swag Offroad makes a few laser cut grinder hangers, and others have made similar things on a plasma table.
http://www.swagoffroad.com/Grinder-Wall ... _p_47.html
-Josh
OMG. for 60$ I can buy a lot of 1/8 x2 flat stock to weld on to every work bench and wall in my garage for hanging grinders.
hey_allen
    SW Oklahoma
Poland308 wrote:OMG. for 60$ I can buy a lot of 1/8 x2 flat stock to weld on to every work bench and wall in my garage for hanging grinders.
True, but now you have ideas for how to save money on it!
The pricing is part of why I have no personal interest in the company, I can't afford to be buying their toys!
As to my storage, they live hanging off of the front edge of my welding cart's shelf, all side by side.
-Josh
maschinen
    Thu Nov 12, 2015 3:56 pm
Two professional choices are
Pferd Germany
https://www.pferdusa.com
Bronco Germany
http://www.dronco.com/xist4c/web/Grindi ... 19586_.htm
    Tue Jun 26, 2012 8:05 pm
I buy my grinding disks from the local metal recyclers.
These guys know exactly what works, they use it every day.
I did the same thing with 'weed whacker' grass trimmers.
I stop and ask the road crews along the highways.
Most times, they give me healthy samples to try out.
Many years ago, I had trouble sharpening chainsaw blades.
So, I bought the rental shop guy lunch,
and he taught me all about chainsaw blades. Money well spent.
Stick_Welder_Steve
WerkSpace wrote:I buy my grinding disks from the local metal recyclers.
Haha I never knew you could stop by road crews and start asking em questions about grass trimmers :lol:
