- MosquitoMoto
Okay, phase one of the refurbishment of my archaic band saw is done. Finally got my hands on some new urethane tyres. Removed the old rubber tyres - which, as the photo shows, were utterly shot - then cleaned the wheels and fitted up the newies.
Runs quieter, and having corrected the uneven, sloping surface the old tyres had, runs truer, too.
The saw has replaceable bearings, but they are fine for now. Next job is to set up some sort of brush system to stop metal swarf getting to the new tyres and wrecking them. After that, some work setting up the gearing, and then to buy/build a cutting fence. Oh, and add some braked castors so that I can actually move the thing around the shed without needing two helpers...
Kym
- MosquitoMoto
I honestly don't know for sure, Harry. But can't imagine this one running well on the bare alloy wheels...they're pretty shagged. New to the world of band saws, still have much to learn.Harry72 wrote:Didnt think metal saws had tyres on them for that very reason?
My horizontal bs doesnt have any... but my upright wood one does:)
Kym
I was about to point out the same thing. I just got done replacing a set of tires on my used new-to-me Milwaukee portaband, mostly just as part of preventative maintenance on unknown condition hardware.Poland308 wrote:Porta band saws have tires and there used primarily on metal.
I will say, the old tires were thoroughly embeded with rusty metal chips, which I can't imagine did anything good to the blades or the machine overall, and depending on what you are cutting could be an issue there as well.
-Josh
Greasy fingered tinkerer.
- MosquitoMoto
Seeing as there is no hurry to put this old band saw into use, I am currently on the lookout at garage sales for an old vacuum cleaner that I can set up as a swarf/chip extractor just under the cutting table.
I may be crazy, but I have a scheme to fabricate a kinda square funnel underneath the cutting table, connect the vacuum and hopefully extract most of the metal chips/dust before it gets down to the wheels/tyres. Will augment it with some kind of brush system, too. I'm cutting mostly aluminium, so dust and fragments are quite light.
Also, the saw is enormous as it is, so it's not like adding a vac too it will make it any more cumbersome. Feel free to wade in with feedback regarding this possibly misguided scheme.
Kym
Kym
kiwi2wheels
- kiwi2wheels
@Kym
A good idea, not misguided at all. Some of the larger industrial machines ( Moessner, DoAll ) do have a removable chip container drawer under the lower wheel.
Grab yourself a Dust Deputy(cyclone separator)from carbatec to put inline before your vacuum, couldnt imagine trying to get ali chips out of a bag or filter!
https://www.carbatec.com.au/dust-contro ... ust-deputy
- MosquitoMoto
Looks like a good idea, Harry, and locally available, too, but ouch...the price!Harry72 wrote:Grab yourself a Dust Deputy(cyclone separator)from carbatec to put inline before your vacuum, couldnt imagine trying to get ali chips out of a bag or filter!
Thanks for the suggestion, but in the spirit of the project (spend no money...) I'm going to just use a cheapo Vac with disposable paper bags.
But thanks for the tip - looks like a decent bit of kit.
Kym
- subwayrocket
Not hard to make one yourself.. You have a welding machine, right??MosquitoMoto wrote: Looks like a good idea, Harry, and locally available, too, but ouch...the price!
A big empty steel can, small drum or old bucket with a good lid on it where you weld a the feed tube from the bandsaw angled into the side like the separator on the picture, then connect the suction to the vacuum cleaner to a tube dead in the center of the lid.
The air (and chips) coming into the bucket/can will want to swirl around until it gets to the center to get extracted. As it does so the air velocity drops and the heavy chips drop out and fall to the bottom.
Vacuum cleaner will still get (very) small particles and simple dust, but won't get loaded down with the big chunks so you also keep your suction capacity high. Empty out the can/drum/bucket of chips once in a while and keep going..
Secondary benefit is that the bigger hot chips don't get into the paper bag as much, so less risk of a vacuum cleaner meltdown
Bye, Arno.
- MosquitoMoto
Good thoughts Arno, thanks, and yes, another excuse to do some fabricating.
I'll go and stare at my saw, work out some dimensions and take it from there.
Thanks for all the useful input, everyone.
Kym
Kym
