Artie F. Emm
- Artie F. Emm
There's an acceptable range. With propane, I'd run about 10-12 PSI and control actual output at the torch. The oxygen rarely needs to be above 35-40 psi unless you're doing heavy demolition. This is true for oxy/acetylene as well, but many folk waste O2 thinking it should be higher.niftyweld wrote:Otto Nobedder wrote:That is interesting. I have a speculation as to why this post is a cut and paste with "my friend" added, but I won't share it as I won't spoon-feed a possible explanation. I'll wait to see niftyweld's explanation, assuming he offers one.
what is the correct working pressure for oxygen and propan ?
Steve S.
I'm not sure what you mean. Simple heating is done with a rosebud, which come in several sizes. If you mean the pre-heat of metal with a cutting tip, your tip choice is determined by the thickness you're cutting. For 1/4", I'd choose a #0 or #00 tip. The #0 will heat a bit faster, and the #00 will give a finer cut line. It's all a trade off.niftyweld wrote:Could you recommend a tip for heating but one without a massive flame?DLewis0289 wrote:I am suspicious of anyone that posts a link that is selling 7018.125's for $3.50 per pound and say's hurry now and stock up before they run out
The_Fixer
- The_Fixer
I'll attempt some sort of answer here....
When I last worked for a large manufacturing company in Brisbane, we had a CNC oxy/LPG profile cutter.
It ran OK. It was down to costing where LPG was deemed to be cost effective because of its significantly lower cost per bottle.
In practice, LPG took considerably longer preheat times, particularly on heavier sizes and needed slower cutting feed rates. There were many, many times when the cutting stalled and required winding the program back and restarting the cut. To be fair, this was also because of pushing the feed rate to an unreliable "run" level, or just a tad too fast. We occasionally cut up to 6" thick steel. LPG had real problems with that.
Eventually, the company was convinced by a gas sales rep that LPG was actually more expensive to use than acetylene, largely because of the variety of steel thicknesses we used and that LPG gave lower temperature output than acetylene did and subsequently used more gas to produce the cuts, which along with the increased oxygen usage to help compensate this as well.
At the end of the day, the sales rep convinced the company that it would actually be cheaper to run acetylene over LPG, even given the higher unit cost of acetylene. So we switched our machine to run acetylene.
We never went back to LPG.
The workshop stayed on it though, as we piped our gas in from a main tank and it was just too expensive to change it over.
Least honorable
- Least honorable
DLewis0289 wrote:Today my good friend is your good fortune! I have the exact tip you desire for your metal working endeavors. I am also a Barrister from the town of Pupe Nigeria, and as good fortune would have it the manufacturers of these miracle tips is located right here in Pupe!
The good news is the tips are only .33 cents in US dollars. The bad news is they can only be purchased here using Naira (Nigerian currency). Our oppressive regime has mandated our minimum currency exchange is $1000.00 US dollars.
Not to worry my friend! Send me $1000.00 US dollars and I will hastily purchase the miracle tip and mail to you a cashiers check for $999.67 with the tip.....I don't know if you noticed but, FREE SHIPPING.
You must hurry my friend, with our volatile government the availability of currency exchange may not be available much longer.
In the highest regards.
B.S. Alaut esq.
sounds like a good deal to me
this gave me a giggle, well played
noah
