Tommy2069
    Sun Jun 05, 2016 10:03 am
i only buy one grit and thats 40 grit i put all my old disc in a box and use the old ones to polish the metal and the new ones to take off metal .by the time i throw them away they are used up to the max.
Boomer63
    Fri Sep 12, 2014 11:52 am
    Indiana near Chicago
I have a rubber or plastic backer for my Milwaukee angle grinder and some sand paper discs. From the contractor supply store down the street, I can get the sand paper discs for .10 cents if I buy 10 or more. Any grit. Attaches to the backer with a set type bolt, which holds down the backer and disc. I take the weld down with a regular grinding wheel, and detail with a sander disc. Easy and cheap!!!
I used to work at a place where we used those sanding discs for almost everything. They even bought a cutter that looked like a can opener. You could cut down an old used 6inch disc and turn it into a new 4 inch disc.
homeboy
    Mon Dec 19, 2016 11:52 pm
    Southern Ontario Canada
For the heavy hogging I use the 4o grit Pro Point 41/2in flap disk from Princess Auto ( The Canadian Harbour Freight ) and the 60 grit Abmast for cleanup if needed. These are both zirconia grit - cut like crazy and wear very well. If I need to fuss up a bit for paint I give a quick touch up with cheapo 120 grit aluminum oxide disks I pick up at the local Dollar store. They wouldn't last long for production work but as metal working is just a hobby for me they do just fine. Have Fun. :P
Rudy Ray
    Tue Jan 24, 2017 7:36 pm
    Fresno, California
I have found 9x out of 10 you get exactly what you pay for. A local company has these made with their name on it from a small manufacturer. They are not cheap, but a little less expensive than the big name brands and last just as long if not longer.
http://www.jiscodirect.com/index.html
I buy their jumbo flap discs in 40 mostly, 80 if I'm polishing up SS.
I will also only buy Carborundum Gold 6" cut off wheels, don't chatter or wander when you start, cut fast, don't chunk, and last all day, and they don't come apart no matter what you do to them. I've seen too many people get hurt from cheap cut off wheels.
