andygmac wrote:...I think I could have done better, but I'm always self critical...
Cheers Andy
Not the first time I've said it...
We like to call ourselves craftsmen, so we are always our own worst critics.
Axis
    Sat Mar 29, 2014 3:41 pm
Is there a pre-heat on those plates?
andygmac
    Sun Jan 26, 2014 5:44 am
    Suffolk England
Nope, no pre heat, just ambient temperature which was around 28°c in the shop
Andy
Axis
andygmac wrote:Nope, no pre heat, just ambient temperature which was around 28°c in the shop
Andy
At the school I go to, 12mm (1/2 inch for us barbarians), is about the beginning of the range where we start to pre-heat. Not sure if your spec allows for it or not. Is there a interpass temp you have to maintain?
We also slow cool by burying the parts in a bucket of sand, again, entirely up to spec.
andygmac
    Suffolk England
I got the test results back today, passed the procedure test for multi run 20mm fillet, failed on procedure tests for, 12mm single fillet, and 12mm multi run v butt, both failed on "hardness in heat affected area" . so my weld shape, leg length, fusion, penetration, macro, and x-ray were fine, just failed on something that I can't check myself to improve on lol
So, I'm happy in a way that I passed one procedure test, (being the first tests I have ever attempted, and knowing procedure tests are scrutinised more than welder tests)
But gutted that I failed, not on my weld as such, but on the surrounding base metal , grrrrrrr.
Andy
Axis
Hardness in the HAZ is usually caused by too quick of a cooling cycle, and is extremely common in MIG/GMAW and on thicker material. As I mentioned before, a pre/post heat, and slow as possible post-weld cool down will reduce the possibility of that happening.
Read up on cold cracking and hydrogen diffusion.
Hobart has an easy to understand article on it.
http://www.hobartbrothers.com/index.php ... turnid=523
andygmac wrote:I got the test results back today, passed the procedure test for multi run 20mm fillet, failed on procedure tests for, 12mm single fillet, and 12mm multi run v butt, both failed on "hardness in heat affected area" . so my weld shape, leg length, fusion, penetration, macro, and x-ray were fine, just failed on something that I can't check myself to improve on lol
Andy
That's the story of a welder's life. If you meet a man who's never busted a test, you've met a liar.
andygmac
    Suffolk England
Axis wrote:Hardness in the HAZ is usually caused by too quick of a cooling cycle, and is extremely common in MIG/GMAW and on thicker material. As I mentioned before, a pre/post heat, and slow as possible post-weld cool down will reduce the possibility of that happening.
Cheers for that :-)
Pre and post heat would be an option but we are trying to avoid this because if any heat is used in the procedure test, then it would have to be used in every weld thereafter which in our production would cost time and money lol
The strange thing with my fails were that they were both on the 12mm plate, one v butt multi pass (7passes), and one single pass fillet. The passed test was 20mm plate multi pass fillet. It was hot on the test day with the workshop having an ambient temp of around 30°c. All test pieces were allowed to cool on the bench, no quick cooling.
There were no cracks found in any of the welds, they were x rayed, mpi, cut, bent, etched, impact tested, and inspected under a microscope, and the fail was hardness in the haz.
A good workman always blames something else, so I'm blaming the 12mm plate ;-) he he he
You are right Steve my motto is " he who has never made a mistake, has never made anything" ;-)
    Thu Jan 24, 2013 10:13 pm
    Eddy, TX
Cheers for that :-)
First thought, you can put the test piece in a bucket is sand or wrap in fiberglass, this will allow for a slow cool and you might be able to get away with this. However, it is best to figure out why this is happpening and how to fix it. I would hate for you to have problems in the future.
Ok now define "hardness in the HAZ". What was acceptable and where did you fall? I will try to get a friend to help out with this one, hopefully.
Steve,
Took the words right out of my mouth!!
andygmac
    Suffolk England
Cheers Jonathan, I'm waiting for the paperwork to come back to me, the test lab is real busy at the moment so they just emailed my results to me, with the paperwork to follow, hopefully this will give me more of an idea what went wrong, I'm still blaming the 12mm plate lol
Cheers Andy
    Eddy, TX
Andy,
Anxious for a update! What did you find out?
andygmac
    Suffolk England
Hi Jonathan, would you believe I only got the paperwork through today :-)
My butt weld passed on every test bar the hardness test, it had 38 different "dots" where it was tested, from parent metal through haz, through weld, through haz on other side, and into parent metal . out of the 38 dots, 2 were over hard, gutted.
Much the same results for the single pass, and pipe to plate test.
The strange thing was, there was only hardness in the 12mm plate in all tests, there was no hardness in the pipe in the pipe to plate test , only the plate?
Another thing I noticed was the hardness of the actual unaffected parent metal, the 12mm plate was 11% harder than the 20mm plate, and 17% harder than the pipe, but they were all supposed to be the same grade, S355j2.
So the 12mm plate was harder to start with, if it had been 10% softer I may have passed?
Just got to get a new batch of steel, and get the inspector round again and give it a go again, at least I know I can weld to a standard, so bring it on lol
Cheers
Andy
