4G MMAW
Posted: Thu Feb 04, 2010 8:34 pm
by Horse
Hi guys,
I'm an Aussie Boilermaker in heavy construction. I mainly do iron ore plants,coal plants and the occational gas power station. As a boilermaker I actually don't do a lot of welding these days as it is mostly prefab and brought to site. However I'm being called upon to do more and more 4G. Now to my challenge.
I seem to always have trouble with the weld not getting enough penetration ie. not gathering the top edges. The weld tends to sag or I just can't get the penetration. We can't use a backing strip in most cases. I've tried using a knife edge V butt joint with and without gap, with landings with gap. with various amperage settings.
I've watched various videos but they do not show joint preparation. I try to keep the stick at 90 degrees with a tight arc. Over here we use 2.6mm 7016 for root runs and then 3.2mm 7018's for hot passes and capping.
What are your thoughts??
Cheers Horse
Re: 4G MMAW
Posted: Thu Feb 18, 2010 7:10 pm
by mwallace61
Can you run it with a 6010?
Re: 4G MMAW
Posted: Sun Feb 21, 2010 9:42 pm
by rickbreezy
well, where i'm at we use 6010 for an open butt v groove weld for penetration, it always does the trick. As for a backing strip, I think you should angle the rod away from the puddle, this will help the arc to dig in a bit better. It works for me, anyway.
-Rick
