Hey Superior,
What kinda gig you got? I wouldn't mind getting in on some work in like that.
Arizona SA200
- Arizona SA200
hey guys,
I really appreciate all of the advice on this subject..its been great. After reading thru your stuff..I guess I may just be over thinking/over reacting...which is good news to me. Superior, I can use a grinder and definitely will, haha. I took a test last week and failed it with a 1/2" slag inclusion..pretty disappointed, but on to the next one. I have another one coming up soon...a few days from now..little nervous, but again, with the advice here and the fact that you don't think that the slag in the side is too bad, that makes me feel more at ease. About the rods..I bought some Lincoln Excalibur 7018MR (3/32)..took them out of the can and put directly into the oven. Started welding with them about an hour and half later and it almost seemed like the slag was even more rough to come off than the other Lincoln rods we have...that seriously frustrated me..I actually stopped welding and decide to take a break. It's just that stubborn hot pass that is getting me, it always leaves a little undercut in the bevel(s) and slag in the toes. I've tried every type of heat/dig combo within the specs...can't seem to find a sweet spot...it almost feels like I've regressed in the last week. Like i said, the fact that I will use a grinder and I only missed by 1/2 inch makes me feel a little more comfortable tho. Thanks to all who helped me out with advice, it is greatly appreciated and has definitely helped. I'll keep yall posted...
http://www.youtube.com/watch?v=OCdmlTxq1Co
http://www.youtube.com/watch?v=FBuscHRI9ko
Here's some 7018 uphill video's with some good arc shots.
Hope this helps,
John~
Hope this helps,
John~
Arizona SA200
- Arizona SA200
Where is that thumbs up button when you need it???? Good job man!!!
Got any pics?
SkyDawg,
Congratulations!!! So how did all your passed go? If you passed that must mean that you over came all obstacles. Hope this cert lands you a great job!!
My passes were pretty good. Again, the hot pass had some slag...had to grind carefully...but in the end it worked out. Cover pass went on nice and smooth, at least it felt pretty smooth. What I realized is that I have to find a way to calm my nerves a little bit...cuz the day after I tested...did some welding at work and things were clicking...no issues. Pics soon
Arizona SA200
- Arizona SA200
I'm sure we can all understand the nerves. Gets even worse when its not I want this job but I NEED this job.
Yeah, the "test anxiety" goes up exponentially when "need" is more important than "want"...Arizona SA200 wrote:I'm sure we can all understand the nerves. Gets even worse when its not I want this job but I NEED this job.
I've experienced it, and suffered because of it...
Well said Otto, this was kind of a 'need to pass' for a 'want' gig..if that makes sense. Anywho, here are a few pics of the finished root and then the cap. Should have tried to get better shots. I also think they look a bit better in person. Bottom line is, I passed and the nerviness is over...for now.
- Cover/Cap--Came out pretty decent seeing as my nerves were peaked
- Cap1.jpg (56.28 KiB) Viewed 1977 times
- Root
- Root2.jpg (71.43 KiB) Viewed 1977 times
- Root pass...wish I had a close up
- Root1.jpg (69.56 KiB) Viewed 1977 times
Congratulations!
Nice root, in particular.
Bend test? Four bends (two root, two face), or six (add two side bends)?
Arizona SA200
- Arizona SA200
That is a nice lookin root pass.
Excellent work my friend!!!
Congrats on passing the bend test!!!
Good luck on the job it lands you....
~John
~John
