Greg From K/W
    Sun Nov 27, 2011 8:55 pm
I though that you could only get CWB certification for the process that you are working on? For an employer. Its the process you learn while working for a period of time and then the employer gets you the certification for that process? Is that wrong? I have been a bit confused by that. Its how the instructor told us it happened way back while i was being trained in it.
    Thu Jan 24, 2013 10:13 pm
    Eddy, TX
Greg,
I think the CWB's website will answer most of your questions. I do not know a lot about Canada's welding certifications, so this will probably be a better help.
http://eng.cwbgroup.org/Certification/P ... fault.aspx
