It is currently Sun Feb 18, 2018 2:10 pm Advanced search
Radiograph 1" plate test 3g
Re: Radiograph 1" plate test 3g
Postby Woodbutcher » Thu Apr 21, 2016 7:41 pm
Thanks for the advice, im pretty sure I have to test dc reverse polarity. Will try the lead wrap idea, ill try anything at this point. Im actually the only one welding at this point, so ive actually tried different machines and different booths with no change. I have the coupon tacked hard at the top with the ground clamp above it normally. Everything was going great until a couple weeks ago when I started having this problem. When welding the root I can get within an inch of the top of the coupon, then arc blow. I've learned that I can drop my elbow and get the rod angle steeper and work it and I can get to the top. However it looks hideous, and im afraid it may not be clean weld. Not sure. Ive never taken an ex ray test, not sure if that portion would pass.
Woodbutcher
Postby Poland308 » Thu Apr 21, 2016 8:10 pm
Don't be afraid to fail. You can always try again.
Postby Woodbutcher » Thu Apr 21, 2016 9:10 pm
You're absolutely right, I guess when you put so much time into something you pressure yourself to the point where nothing but perfection will do. Pass or fail I am twice the welder I was a year ago, and confident enough to say so.
Woodbutcher
Postby Otto Nobedder » Fri Apr 22, 2016 11:43 pm
Woodbutcher wrote:You're absolutely right, I guess when you put so much time into something you pressure yourself to the point where nothing but perfection will do. Pass or fail I am twice the welder I was a year ago, and confident enough to say so.
Here's a big, fat, "LIKE" for that comment. :!:
Otto Nobedder
Postby Woodbutcher » Sat Apr 23, 2016 9:12 pm
Well thanks for that, however I've been wrestling with this since I replied to Poland. I would say to not be confused with 'don't be afraid to fail' with 'its ok to fail'. Big difference. A lot of us, including myself weld for a living, this test could mean a job which feeds my family. Its not ok to fail. If I fail this test, to retest it requires an additional fifty hours of training before retest. Which would take place forty five minutes from home, hopefully after eight hours of work, if the Instructor had time and chose to hold the class. So after rethinking this, I think a prudent person would be afraid to fail, and I m ok with that. Just a side note, God bless my instructor, he's fantastic.
Woodbutcher
Postby Otto Nobedder » Sun Apr 24, 2016 12:12 am
I understand that, too.
I've driven 1300 miles for a make or break test more than once.
I've failed one, too.
That's a quiet ride home... I don't even want the radio for companionship at that point.
Otto Nobedder
Postby Woodbutcher » Mon May 16, 2016 9:05 pm
So the test was saturday may 7th. I've had some time to think about it now, its been over a week. I'm confident, but a little reluctant to celebrate. I didn't have any major issues while welding. I won't get the results back for couple more weeks, they get sent to the state capitol where they are measured and ex rayed. Just a note to other students out there, work hard and you will see improvement. It may be frustrating at first but it gets better, stick with it.
Woodbutcher
Postby Diesel » Tue May 17, 2016 12:22 am
Havnt followed this thread but just caught up on it. Sounds like you got it. A lot of times when you're frustrated like that you have to take a break and come back. But your mind tells you to try again. Ive only failed 1 cert and that was my stainless pipe 6g. Purge fell out and I couldn't redo it. Auto fail. Worst 3hr drive of my life. If you don't make it, just take a breath and go at it again. I would try to weave as much as I could as it burns hotter and seems to leave less crap in there. But stringers are quick and get the job done too. Just gotta get the smooth motion down. I hope the results then out well in your favor. Good luck
Diesel
Postby DLewis0289 » Tue May 17, 2016 8:12 am
When I fail I blame it on the welding machine, the rod, the position of the moon. It happens, anyone tells you it doesn't they are full of it. Nothing worse than doing a heavy wall 6G and the inspector says "you will not radius the corners on the straps", edges are a crap shoot sometimes.
One thing I can be for sure of, a picture of that Alaskan fellas root pass belongs in a welding text book.
DLewis0289
Postby Otto Nobedder » Tue May 17, 2016 8:02 pm
DLewis0289 wrote:When I fail I blame it on the welding machine, the rod, the position of the moon. It happens, anyone tells you it doesn't they are full of it. Nothing worse than doing a heavy wall 6G and the inspector says "you will not radius the corners on the straps", edges are a crap shoot sometimes.
I can relate to blaming the moon phase. I can blame a machine, in one case, because of a gas coverage issue, but that's still on me, for not recognizing it at the time.
If by "that Alaskan fella", you mean John, AKWeldshop, you'd be stunned by how young this exceptionally talented fellow is.
Otto Nobedder
PreviousNext
Return to Welding Certification - Stick/Arc Welding, Tig Welding, Mig Welding Certification tests - Welding Tests of all kinds
