It is currently Sun Jan 21, 2018 2:26 am Advanced search
CWB Level 1 Practical Exam
Re: CWB Level 1 Practical Exam
Postby mostafizur » Sat Oct 08, 2016 4:16 pm
Can anybody please help me with level 1 practical exam advices specially how to measure?
Thanks!
Mostafiz
mostafizur
Postby mostafizur » Sat Oct 08, 2016 4:56 pm
Otto Nobedder wrote:Kasey's stats say he last visited May 19, 5 days after he joined. It's not unusual for someone to come here with a specific question and move on after it's answered.
There are others here familiar with that test, though. You may need to start a fresh topic to get their attention, though.
Thanks for the advice
mostafizur
Postby TrunkMonkey315 » Wed Oct 12, 2016 4:02 am
I'm a Journeyman/Red Seal welder and I managed to fail the practical the first go. I also didn't follow the instructions and circled more than one fault on my samples. I asked the lady at the front desk what I should do if I find more than one, her reply was "pick the most obvious". It is a fairly easy test, if you see a fault right away that's the one you should mark down. Once you identify it measure it and compare it to the generic welding standard they give you and either accept or reject the sample making sure to mark down the size of fault you observed.
What problem with measuring are you having? The easiest way if you haven't had any training in inspection tools is look up youtube videos. There's several available that show you how to use the gauges provided for the exam. (Vwac, fillet, bridge cam, hi lo and a basic ruler.)
TrunkMonkey315
Postby MakeWeldsNotWar » Sat Sep 23, 2017 5:39 pm
I'm about to take this exam and was wondering if it's multiple choice, and if not, how much descriptive writing is involved. Any other tips would be appreciated too!
MakeWeldsNotWar
Postby med415 » Tue Dec 05, 2017 6:53 am
I am only on mod 4 on the theory for level one and I have been waiting 4 months for the grades going to move on and hope I did not fail anything
med415
Postby Rebeliron » Tue Dec 12, 2017 9:35 pm
I passed CWB CWI level one and it's no joke. Read the instructions is the first part and follow it to a "T"! That's your first test as an inspector. No over thinking it, that will be your downfall. You must follow it exactly and ONLY CIRCLE ONE discontinuity (pick the easiest one and not all discontinuities are weld faults), pass or fail it, use the right term for the discontinuity (no slag, there are multiple choices but not all of them are the correct terms.) and measure the discontinuity, if it is measurable (not all discontinuities can be measured). In my class there were 12 students and only four passed, i believe. Just remember, in level 2 you need to redo level one (so keep your books)and you need to work for minimum of 2 years under a level 2 or 3. Level 2 CWB CWI is more like AWS CWI and in level 2 it is a less than 10% pass rate. It's best not to talk about level 3 (lol). Good luck and don't use the palmgren gauge, the bridge cam is your best friend. :D
Rebeliron
Previous
Return to Welding Certification - Stick/Arc Welding, Tig Welding, Mig Welding Certification tests - Welding Tests of all kinds
